thanks for your help, I got the truck back disassembled and lots of bolts missing.
The Mitsu catalog shows it's M12, 25mm long. Part number is MF244905. $2.60-ish. Quantity 8. The thread pitch isn't listed, but I'd guess 1.5? If it's like most Mitsubishi chassis bolts, it's probably got a captive flat washer and lock washer. It was used on all the pickups, as well as all the Monteros up to 2000 and all the Montero Sports if you want to try a junkyard. Otherwise, any place with a decent selection of metric bolts should have what you need.
$20-25 at the dealer is hard to beat though. By the time you buy the washers, I doubt you'll be much cheaper at the hardware store.
your awesome! thanks Jeff V.
It's a bootleg version of the Mitsubishi Aftersales Support Application. (ASA) It's probably the most valuable Mitsubishi 'tool' I have. I don't know this board's position on discussing details of how to get it since it's in a gray legal area. Look for Mitsubishi ASA on Google and you should be able to take it from there.
I also bought a giant 20 lb parts book that came from a Chrysler dealer. One day I need to get around to scanning the Ram 50 pages.
Thank so much. I called fastenal and they have the bolts and i already have washers. Cant wait to get this the pr50 on the road.
Darn! 1.5 was not it.... any other suggestions?
I'll pull one out of my truck tonight and measure it.Quote:
Originally Posted by rida4christ
M12x1.25, 17mm hex. Captive lock and flat washers.
Attachment 17818
I love having a 4x4 truck. Even if it's just a little one. I only have to jack it up if I want to take the wheels off :D
I have the 20 lb. Chrysler parts book + updates so if anyone needs a lookup I'll try to help. I also have the ultra rare service manual for the hi end audio system that was an option in out trucks(special double din radio hole dash plate. It is actually a manual on the radio that is how complicated they were -go figure...
Wow. I'd really like to see that stereo manual.
ok update, finally installed the bolts and we are good thanks so much Jeff V. I might need some more bolt help later.;]
