run on after shut off problem
1988 dodge ram50 sport 2.6l with a Weber 32/36 DGEV Electric Choke :
Quick Fuel Carburetor 1-4 PSI ADJUSTABLE LOW Fuel Pressure Regulator
temp here is running in the high 90's with high humidity
i have adjusted this thing so many times it isn't funny and still it wants to run on from time to time
it don't do this all the time just when it seems to be very hot:
now i haven't adjusted the fuel pressure reg sense i got it so it is set @ factory:
what i,m wanting to know do you think that maybe the pressure is set too high?
should i turn it down a few turns?
what is a good set to run?
thinking about getting a gauge to put in line.
what pressure should the carb run with this engine?
the engine doesn't smoke burn oil
another point of fact here is sometimes if i don't run it for a day or too
it's hard to start almost like there is no fuel in the carb.
most times i can turn the key and it will fire up.
any advise will help thanks
