Weber 32/36 High idle issue
I have an 88' Max with a 2.0L and I finally was able to get a 32/36 for it because as you all know that Mikuni POS wasn't wanting to run anymore. Once I installed the carb the truck started right up, but went up to 2000 RPMs and ran for about 30 secs then died and thats the same thing it does everytime, I can however keep it running by feathering the peddle, and sadly the RPMs will not drop while running. I am still using the mechanical fuel pump for now as i'm mainly testing and adjusting the carb. I have ordered a carter 40/70 pump that will take the place of the old pump.
If needed I can take pictures of the engine bay.
Also I am still kind of new to messing with carbs as this is only the 5th one i've worked on.
