Oil leak in the front, not the camshaft seal, so I will have to replace front case?
Hi all,
My truck is a 1993 mighty max with 4G64 engine. It runs good and never let me down. The only thing is it leaks oil pretty bad. I thought it was the camshaft seal, but I have replace that seal twice it still leaks. A lot of oil on the alternator. I am thinking of the oil pump / front case. Looks like the front case is the oil pump, correct me if im wrong. It could also be silent shaft seals... I will have to fix it. Any suggestions? And yes i have checked PCV. It works. And I have put on new valve cover gasket and put rtv around. Shouldn't be leaking around the head or the camshaft seal.... The only place is the front case... Is it gonna be a big job? I have changed clutch and timing belt, water pump, lash adjusters on this truck before. I know this truck quite good, but I have never dealt with the front case....Any suggestions or inputs are highly appreciated.
