Hey Guys curious about the vacuum advance after installing a weber 34/34 (im getting ready to install a 32/36 figured id go ahead and ask the question) there is enough vacuum on the distributor to almost fully advance the timing at idle should i set the timing with the vacuum line hooked up? also how much timing are you running on your G63B 2.0? any comments welcome!
