4D55t in 86 ranger injection pump adjustments
Hello all,
I had the pump rebuilt after the motor was rebuilt but ran flat out due to rusty internals from having sat with bio fuel in the south for two years. Now when attempting to start it does not want to idle. In my ford service manual it has a section 25 that is "optional" and can be purchased additional -and of course that is where the injection pump adjustments are located. Any one help with info on procedure to set pump correctly ? If pump is loosened on motor, which way to adjust to increase timing- my guess is pull away from motor? This may not be necessary as maybe the pump rebuilders did not set an idle screw correctly? Sorry for the long winded post here but working on this for a friend and it is her primary vehicle- and she is borrowing mine until its fixed so let the games begin!
