vacuum advance question
Trying to hook up the vacuum advance to the weber 32/36. But my vacuum advance diaphragm has two ports, and im not sure what to do with them. One port went to the stock mikuni, and the other went to the vacuum regulator valve. Im assuming the one that went to the mikuni is for high rpm and the other is for low rpm. And im also assuming i must eliminate the port going to the vacuum regulator, and connect the port that originally went to the mikuni. Thank you! :)
If anybody knows, please help :)
