No low beam on my 91.
The low beams are out on my son's 91, high beams work fine. Swapped out the control switch with a known good one but got same result. Wiring diagram shows a combination meter between the switch and the headlights but I can't locate it. Any help would be appreciated.
Never mind, turned out to be faulty fuse connection. I always tell myself to stick with the simple stuff first, should have listened to that little voice!
Ive had the same trouble with my fuse connection, and a few others I know have too.
hahaha you fixed it in 50 minutes..
