i did a drive shaft overhaul this weekend. new u-joints, almost new center bearing from my 84 mm.
i went to put the shaft back in and had to pull the rubber suspension in the center bearing about 1/4 " toward the rear to bolt it to the diff flange.
oops!
will it screw up anything like this? should i pull the shaft again spin the bearing around?
freaking mosquitoes biting and termites swarming had me rushing the work..:shrug:
