What is wrong here?
Replaced head gasket and other gaskets. new plugs turned distributor 180, new starter too. everything tdc when replaced. Idk whats going on but when I try to start the engine it wants to start it starts to fire then dies on me. at a loss again. 87 Ram 50 G63B 2.0.
Did you pull a plug while cranking it to see the condition of the spark? Getting fuel.
This is a duplicate thread, he has 2 with the same problem shown. Might check for the other thread to answer.
Here is his other thread which probably would be best to only use one.
http://www.mightyram50.net/vbulletin...0053#post30053
My bad. computer did it for some reason. :shakehead:
yes i checked the plugs I want to say its getting full and is running a little lean.
