4WD and sport cluster?
Does anyone here know if the sport cluster from the 2WD MM is compatible with the 4WD model? I would like to avoid some work and save some time of installing a tach and such by using the sport cluster, but I'm not sure if the lights for the 4WD and wheel lock exist in the sport cluster.
you may be able to swap the tach into the 4wd cluster - I know you can on the 1st gen - never looked at a 2nd gen. You may also need jumpers or additional wiring for the tach to get the signal from the dist.
I can get one from the junk yard for about 10 bucks so I'll just experiment with it, if it doesn't work maybe someone here will want it.
