Page 1 of 11 123 ... LastLast
Threads 1 to 25 of 275
Forum: Diesel
Have a BIG Brute of a Diesel, or you just need help with the stock one? Get the answers to your problems in here.
  1. Sticky Thread Sticky: Engine Part Numbers 4D55 4D56
    Started by camoit, 10-18-2012 05:59 PM
    07-13-2013, 04:12 PM Go to last post
  2. Sticky Thread Sticky: Diesel Links, Turbos, Injectors, Parts and builders.
    Started by camoit, 12-04-2012 03:34 PM
    diesel, injection, injectors, pumps, turbos
    12-17-2012, 01:09 PM Go to last post
  1. 84 mighty max 4wd diesel wire diagram
    Started by EDELIORLANDO, 06-09-2024 07:04 AM
    06-09-2024, 07:04 AM Go to last post
  2. 4D55T Alternator
    Started by Furiosa_D50, 01-04-2024 02:53 PM
    4d55t, alternator, diesel
    05-29-2024, 12:38 PM Go to last post
  3. 4D55 Water Temperature Question
    Started by Sandrailstudent, 09-14-2023 12:25 AM
    12-27-2023, 11:18 PM Go to last post
  4. 4d55 Rough idle and Lots of white smoke
    Started by 1985Dodged50, 03-07-2017 09:30 AM
    08-01-2023, 09:49 PM Go to last post
  5. Possible additional source for parts
    Started by mopar_ja, 09-01-2022 04:03 PM
    09-01-2022, 04:03 PM Go to last post
  6. Replacement injector hard lines for 4d55t
    Started by emersonthis, 07-10-2022 09:42 PM
    07-23-2022, 02:35 PM Go to last post
  7. Conclusive info on 4D56 head onto 4D55 block info?
    Started by gard, 05-30-2019 04:38 PM
    3 Pages
    1 2 3
    04-04-2022, 08:01 AM Go to last post
  8. Delica Automatic
    Started by Maxedoubt, 03-23-2022 12:51 PM
    04-03-2022, 02:37 PM Go to last post
  9. 4D55/6 ARP Head stud part numbers
    Started by JeffTheMarine, 11-21-2017 07:52 AM
    04-03-2022, 10:00 AM Go to last post
  10. QCH 4D55 parts
    Started by Maxedoubt, 01-05-2022 07:39 PM
    01-05-2022, 11:03 PM Go to last post
  11. no start after installing injectors 2,3L
    Started by gustycrosswinds, 10-26-2021 03:00 PM
    12-01-2021, 03:38 PM Go to last post
  12. Puff the magic dragon
    Started by Bjamin, 02-25-2020 05:49 PM
    10-17-2021, 12:57 PM Go to last post
  13. Coolant doing weird things
    Started by Jmuirhead9, 03-29-2017 09:24 PM
    2 Pages
    1 2
    10-16-2021, 01:11 AM Go to last post
  14. ford and dodge head differences
    Started by weelsey, 09-21-2021 08:28 AM
    10-13-2021, 07:26 AM Go to last post
  15. fuel pump pressure for first gen
    Started by gustycrosswinds, 04-14-2020 06:47 AM
    10-13-2021, 07:05 AM Go to last post
    08-21-2021, 03:24 AM Go to last post
  16. Cylinder Liners
    Started by Maxedoubt, 06-23-2021 07:31 PM
    07-01-2021, 07:13 PM Go to last post
    03-03-2021, 11:31 AM Go to last post
  17. Hand throttle cable
    Started by gustycrosswinds, 02-29-2020 06:49 AM
    02-25-2021, 12:27 AM Go to last post
  18. Tc05 turbos?
    Started by Balcorn80, 01-05-2021 05:38 PM
    4d55, 4d55 turbo, tc05
    01-17-2021, 01:55 PM Go to last post
  19. Part identification question, 4d55 (picture)
    Started by SuperSloth, 03-12-2017 04:10 PM
    2 Pages
    1 2
    01-13-2021, 08:03 AM Go to last post
  20. Source for a head, head gasket question
    Started by Topher, 04-17-2019 06:02 PM
    01-13-2021, 07:32 AM Go to last post
    01-03-2021, 09:51 PM Go to last post
  21. 4D55 expert in DC area?
    Started by smketrny, 03-07-2020 09:23 AM
    11-29-2020, 12:10 PM Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
