Page 17 of 17 FirstFirst ... 7151617
Threads 401 to 416 of 416
Forum: Tuning & Smog
Is your baby not running right, or just wont start, pinging, smoking, or you are really stuck? Here is the place for you.
  1. Sticky Thread Sticky: Thinking about buying a weber carb? Becareful!!!!!!!!!!!!
    Started by mighty spx, 11-16-2013 04:10 PM
    2 Pages
    1 2
    05-18-2022, 09:39 AM Go to last post
  2. Sticky Thread Sticky: Vacuum Diagram
    Started by blessedguy, 12-15-2012 12:25 PM
    2 Pages
    1 2
    08-24-2021, 04:08 PM Go to last post
  3. Sticky Thread Sticky: 2nd gen electric fuel pump install
    Started by originalowner, 01-15-2014 12:11 AM
    2 Pages
    1 2
    10-05-2015, 09:42 PM Go to last post
  1. Compression
    Started by tekjones83, 12-21-2011 02:35 PM
    compression
    12-22-2011, 09:01 PM Go to last post
    12-17-2011, 11:52 AM Go to last post
  2. Angry 88mm tryin to kill itself
    Started by dazednconfused, 06-21-2011 02:23 AM
    2 Pages
    1 2
    88mm, kill, tryin
    12-06-2011, 08:57 AM Go to last post
  3. need G54B timing curves
    Started by PowerRam348, 11-15-2011 06:13 PM
    curves, g54b, timing
    12-01-2011, 12:24 AM Go to last post
  4. (SOLVED) truck still wont run
    Started by joey_crandall, 04-12-2011 08:17 AM
    6 Pages
    1 2 3 ... 6
    run, truck
    11-27-2011, 07:35 PM Go to last post
  5. Truck slalls need help!!!!
    Started by Medevack1, 11-15-2011 07:16 AM
    slalls, truck
    11-17-2011, 10:36 PM Go to last post
  6. coolant dripping of catalytic converter?
    Started by 804ram, 09-09-2011 07:58 AM
    catalytic, converter, coolant, dripping
    10-04-2011, 04:39 AM Go to last post
  7. Thumbs up Bent or Broken Valve
    Started by abeemanator, 09-18-2011 08:54 PM
    2 Pages
    1 2
    09-28-2011, 06:29 PM Go to last post
  8. Angry Electronic Ignition Failure
    Started by abeemanator, 06-04-2011 02:07 PM
    electronic, failure, ignition
    09-14-2011, 08:49 PM Go to last post
  9. Maintence Light
    Started by tekjones83, 08-21-2011 11:04 AM
    light, maintence
    08-24-2011, 05:55 AM Go to last post
  10. Is my EGR normal? and other smog stuff
    Started by Arrow, 07-20-2011 03:08 PM
    egr, normal, smog, stuff
    07-24-2011, 06:31 AM Go to last post
  11. Timing help
    Started by abeemanator, 07-16-2011 06:48 PM
    timing
    07-16-2011, 06:48 PM Go to last post
  12. Unhappy More Weber 32/36 Issues, I think.
    Started by abeemanator, 07-12-2011 10:24 PM
    issues, weber
    07-14-2011, 12:19 AM Go to last post
  13. Post CA C.A.R.B. Engine change/swap rules
    Started by DroppedMitsu, 05-09-2011 12:28 PM
    california, engine, rules, smog, swap
    05-17-2011, 10:04 PM Go to last post
  14. 88 Ram 50 2.6L Pings and Looses power
    Started by 88PowerRam50, 05-10-2011 10:34 AM
    looses, pings, power, ram
    05-12-2011, 12:59 PM Go to last post
  15. Unhappy From Rocket Speed to Snail Speed! HELP!
    Started by tekjones83, 04-09-2011 07:16 AM
    rocket, snail, speed
    04-21-2011, 01:06 PM Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
