Page 1 of 17 12311 ... LastLast
Threads 1 to 25 of 415
Forum: Tuning & Smog
Is your baby not running right, or just wont start, pinging, smoking, or you are really stuck? Here is the place for you.
  1. Sticky Thread Sticky: Thinking about buying a weber carb? Becareful!!!!!!!!!!!!
    Started by mighty spx, 11-16-2013 04:10 PM
    2 Pages
    1 2
    05-18-2022, 09:39 AM Go to last post
  2. Sticky Thread Sticky: Vacuum Diagram
    Started by blessedguy, 12-15-2012 12:25 PM
    2 Pages
    1 2
    08-24-2021, 04:08 PM Go to last post
  3. Sticky Thread Sticky: 2nd gen electric fuel pump install
    Started by originalowner, 01-15-2014 12:11 AM
    2 Pages
    1 2
    10-05-2015, 09:42 PM Go to last post
  1. My 2.0 86 Mighty Max is running really rough
    Started by Andres483, 04-02-2024 07:12 PM
    2 Pages
    1 2
    04-16-2024, 05:48 PM Go to last post
  2. 1985 Dodge Ram50 non-start issue
    Started by Reluctant_Rabbit, 07-30-2023 09:52 AM
    03-20-2024, 03:10 PM Go to last post
  3. Vacuum/ canister delete
    Started by ellordito1, 02-22-2024 11:12 AM
    canister, delete, emissions, vacuum
    03-03-2024, 12:30 PM Go to last post
  4. Dies when stopping
    Started by Gibbie1233, 01-15-2024 07:04 PM
    02-07-2024, 05:19 AM Go to last post
  5. No power
    Started by Merg, 03-18-2023 04:32 AM
    2 Pages
    1 2
    12-13-2023, 04:32 PM Go to last post
  6. Starts runs sits poor start?
    Started by Law Dog, 09-29-2023 12:21 PM
    09-29-2023, 12:21 PM Go to last post
  7. Weber with A/C
    Started by Fingers, 09-04-2023 09:13 AM
    09-10-2023, 05:26 AM Go to last post
  8. Question 1991 Ram 50 intermittent hard start condition
    Started by Recon1342, 08-02-2023 07:37 AM
    08-18-2023, 07:27 AM Go to last post
  9. Spark plug heat range
    Started by SubGothius, 08-07-2023 11:21 PM
    08-08-2023, 08:39 PM Go to last post
  10. will not rev past idle
    Started by Chickenhawk, 08-06-2023 04:22 PM
    08-06-2023, 04:22 PM Go to last post
  11. poor idle after a 90mi trip
    Started by Mitsuzero, 07-29-2023 05:59 PM
    carb, g63b, idle, stalling, timing
    08-01-2023, 10:57 AM Go to last post
  12. Weber 38 38 jets for 2.0
    Started by TintedRam50, 05-18-2023 11:59 PM
    06-27-2023, 12:59 AM Go to last post
  13. 95 MM Cranks but refusing to start
    Started by Panda, 05-12-2022 09:18 PM
    06-01-2023, 07:03 AM Go to last post
  14. 1982 G54B carburetor tuning
    Started by WAMM97, 05-11-2023 12:14 PM
    05-12-2023, 04:36 PM Go to last post
  15. Question '94 4G64 idle issues
    Started by doots, 10-09-2022 08:45 AM
    04-06-2023, 04:06 PM Go to last post
    04-04-2023, 07:45 PM Go to last post
  16. Dump pipes and fouled plugs 2g 4g63t
    Started by Georgethepainter, 04-03-2023 01:23 PM
    04-04-2023, 12:24 AM Go to last post
  17. 1989 Ram 50 2.0 blue smoke issue
    Started by jmr92, 01-25-2023 02:27 PM
    2.0ltr, oil burning, smoke
    01-25-2023, 02:27 PM Go to last post
    01-25-2023, 01:33 PM Go to last post
  18. Mysterious issue with 1990 MM 2.4L
    Started by BillHilly, 12-20-2022 05:14 PM
    01-01-2023, 10:02 PM Go to last post
  19. '86MM G63B & Weber 38 Dges tuning issues
    Started by nprboref, 07-28-2022 02:34 PM
    11-23-2022, 11:45 AM Go to last post
  20. '94 Cranks But Won't Fire Up
    Started by Instakill, 08-25-2014 06:49 PM
    10-02-2022, 02:15 AM Go to last post
  21. Installing a weber - what else should I order?
    Started by sith33, 09-17-2022 02:35 PM
    09-25-2022, 01:53 PM Go to last post
  22. High Idle when in neutral
    Started by amp2112, 09-09-2022 02:17 PM
    09-10-2022, 04:24 PM Go to last post
  23. 4g64 blue smoke and inconsistent ticking.
    Started by JesseOnABoat, 08-06-2022 10:02 PM
    4g64, blue smoke, mighty max 2.4, ticking
    09-03-2022, 12:38 PM Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
