Page 1 of 23 12311 ... LastLast
Threads 1 to 25 of 556
Forum: Performance Modifications
So you want to make more horse power? Avoid the pit falls and ask first. Then show off what you have done!
  1. Sticky Thread Sticky: DGheaders Performance header: New design tri-y 2.0 2.4 2.6 g63b 4g64 g54b
    Started by DGHeaders, 12-17-2012 05:56 PM
    5 Pages
    1 2 3 ... 5
    04-27-2024, 05:04 PM Go to last post
  2. Sticky Thread Sticky: Weber 32/36
    Started by Ram50Man, 05-01-2011 05:33 PM
    13 Pages
    1 2 3 ... 13
    02-28-2024, 06:43 PM Go to last post
  3. Sticky Thread Sticky: DSM vs. Evo for RWD Swaps - All the info you need to know
    Started by Merrill, 04-05-2015 12:00 AM
    2 Pages
    1 2
    01-03-2024, 07:43 PM Go to last post
  4. Sticky Thread Sticky: Dual carbs???
    Started by amcervantes, 09-10-2013 07:44 PM
    3 Pages
    1 2 3
    carbs, dual
    02-18-2021, 09:48 AM Go to last post
  5. Sticky Thread Sticky: Starion to 2nd Gen Mighty Max 2.6 Turbo Swap
    Started by BradMph, 02-11-2015 10:09 PM
    01-13-2021, 02:27 PM Go to last post
  6. Sticky Thread Sticky: My Electric fuel pump install
    Started by mopar_ja, 02-11-2012 11:45 AM
    2 Pages
    1 2
    06-07-2019, 07:52 PM Go to last post
  7. Sticky Thread Sticky: Eclipse DSM Dohc 4G63 / 4G63T swap information
    Started by DroppedMitsu, 12-16-2012 03:35 PM
    2 Pages
    1 2
    06-05-2019, 08:39 AM Go to last post
  8. Sticky Thread Sticky: The MSD Thread.
    Started by camoit, 07-08-2013 10:54 PM
    3 Pages
    1 2 3
    01-28-2019, 06:27 PM Go to last post
  9. Sticky Thread Sticky: Natedog's 6g72 Turbo Swap
    Started by Natedog, 12-23-2012 04:33 PM
    3 Pages
    1 2 3
    01-05-2018, 08:27 PM Go to last post
  10. Sticky Thread Sticky: Crazy '88 Ram 50 build: Twincharged-Twinturbo SOHC 6G72
    Started by speednsnake, 03-28-2015 11:24 PM
    2 Pages
    1 2
    02-11-2017, 08:43 PM Go to last post
  11. Sticky Thread Sticky: Balance Shaft Removal, How, Why or Why Not!
    Started by BradMph, 08-23-2014 05:18 PM
    01-21-2015, 06:29 AM Go to last post
  12. Sticky Thread Sticky: 4G64 SOHC to DOHC swap info
    Started by sleeps, 11-06-2013 06:26 AM
    2 Pages
    1 2
    dohc, swap
    07-09-2014, 08:51 PM Go to last post
  1. Weber carb and kickdown issues
    Started by intimidator03, 02-11-2015 11:36 AM
    04-29-2024, 05:49 PM Go to last post
  2. Where to buy cold air intake?
    Started by MMMM24, 04-21-2024 04:04 PM
    04-22-2024, 07:46 PM Go to last post
  3. Helping Hand Tracking Down MightyRam50 Members
    Started by MMMM24, 04-14-2024 08:30 PM
    04-15-2024, 05:27 PM Go to last post
  4. My Turbo'ed 8V 4G64, Complete Write-UP
    Started by Low9Life4, 01-23-2024 05:46 PM
    2 Pages
    1 2
    03-01-2024, 11:53 AM Go to last post
  5. Electric Fan Install
    Started by ram50rocket, 01-28-2024 11:47 AM
    01-29-2024, 12:37 PM Go to last post
  6. Pulley System
    Started by tekjones83, 12-16-2011 09:10 PM
    pulley, system
    12-17-2023, 09:17 PM Go to last post
  7. Do I need a new toe alignment after lowered 2.5in?
    Started by Yuta, 10-31-2023 11:25 PM
    12-08-2023, 10:51 PM Go to last post
  8. Question G63B SOHC to 4G63 DOHC head swap
    Started by superspook, 09-28-2023 09:53 PM
    4g63, g63b, head swap, question
    10-23-2023, 01:35 PM Go to last post
  9. Dying under braking with Weber 32/36
    Started by Boogiefab, 07-22-2023 06:26 AM
    2 Pages
    1 2
    08-30-2023, 09:57 PM Go to last post
  10. Starter motor upgrade
    Started by xboxrox, 03-10-2021 05:53 PM
    2 Pages
    1 2
    08-04-2023, 01:39 PM Go to last post
  11. G54B non jet valve head
    Started by H8PVMNT, 03-28-2023 09:26 PM
    2 Pages
    1 2
    07-14-2023, 10:05 PM Go to last post
  12. Edllbrok pump
    Started by Havelthebonk, 01-23-2023 02:36 PM
    07-13-2023, 03:58 PM Go to last post
  13. Fuel cell swap
    Started by Havelthebonk, 05-02-2023 06:23 PM
    05-12-2023, 07:33 PM Go to last post
  14. 1986 ram d-50 swap 4g63t
    Started by Masterlud, 04-10-2023 12:37 PM
    1986, 4g63t, mighty max 1986, ram 50, swap
    04-13-2023, 05:22 PM Go to last post
  15. Carberated 3.0 what years?
    Started by Law Dog, 04-06-2023 05:55 PM
    04-13-2023, 04:22 PM Go to last post
  16. Absolutely insane question
    Started by Havelthebonk, 03-06-2023 09:24 PM
    carb, ontario, webber
    03-08-2023, 10:39 PM Go to last post
  17. Help Fixing wiring on an SPX with Weber Swap
    Started by CoSut, 01-14-2023 04:36 PM
    01-29-2023, 02:54 PM Go to last post
  18. Fan shroud ....Montero
    Started by Havelthebonk, 01-22-2023 09:37 PM
    01-22-2023, 09:37 PM Go to last post
  19. 2.0 for 79 fitting in a 87 d 50
    Started by Havelthebonk, 01-19-2023 04:37 PM
    01-20-2023, 12:19 PM Go to last post
  20. Super charger
    Started by Havelthebonk, 01-18-2023 04:31 PM
    01-19-2023, 03:37 PM Go to last post
  21. K614 webber kit but not e choke
    Started by Havelthebonk, 01-16-2023 08:56 AM
    intake, kit, webber
    01-17-2023, 06:01 PM Go to last post
  22. Wiring help! 8V 4G64T with 1G Turbo ECU
    Started by Low9Life4, 12-24-2022 07:11 PM
    01-16-2023, 09:04 AM Go to last post
  23. Clearwater cylinder head
    Started by xboxrox, 12-21-2022 11:16 AM
    2 Pages
    1 2
    01-11-2023, 03:25 PM Go to last post
  24. Looking fr genuine webber carb kit
    Started by Havelthebonk, 01-02-2023 07:44 PM
    01-03-2023, 01:08 AM Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
