Page 1 of 62 1231151 ... LastLast
Threads 1 to 25 of 1527
Forum: General Maintenance
Got a Question on a Stock Engine, Cooling System, Charging, or Transmision? Ask them in here.
  1. Post Sticky Thread Sticky: *****Mighty max and Ram 50 combo switches for 55.00 shipped NEw.1987-93***
    Started by maxdsm, 09-13-2015 06:43 PM
    3 Pages
    1 2 3
    01-24-2024, 01:34 PM Go to last post
  2. Sticky Thread Sticky: Fusible links
    Started by xboxrox, 11-17-2020 05:33 PM
    09-29-2023, 03:46 PM Go to last post
  3. Sticky Thread Sticky: What Can Cause Front End Wobbles and Vibrations
    Started by BradMph, 03-15-2015 01:27 AM
    03-24-2023, 11:23 AM Go to last post
  4. Sticky Thread Sticky: Mikuni Carb - The Sub EGR valve - Servicing
    Started by BradMph, 10-01-2017 04:28 AM
    08-31-2020, 03:41 AM Go to last post
    05-11-2019, 05:45 PM Go to last post
  5. Exclamation Sticky Thread Sticky: G52 2.0L Head On A G54B 2.6L
    Started by camoit, 11-13-2012 06:27 PM
    g52, g54b, head
    07-14-2015, 12:18 PM Go to last post
  6. Sticky Thread Sticky: The Myths of Synthetic Oils
    Started by BradMph, 03-15-2015 01:10 AM
    03-15-2015, 01:10 AM Go to last post
  7. Sticky Thread Sticky: Blown 2 Timing Belt, Won't Run
    Started by JaredC, 09-11-2012 04:53 AM
    11-12-2012, 12:43 PM Go to last post
  8. Sticky Thread Sticky: 1985 D50 2.0 Timing Belt.
    Started by mike05307, 12-12-2011 10:47 PM
    2 Pages
    1 2
    01-02-2012, 06:15 AM Go to last post
  1. 1995 Mighty MAX automatic, Shifter sticking
    Started by RHerrera, 04-27-2024 07:18 PM
    1995, 4g64, automatic, shifter
    04-27-2024, 07:18 PM Go to last post
  2. 2.0L with stock carb struggling to idle
    Started by Mitsuzero, 03-30-2024 09:58 AM
    2 Pages
    1 2
    04-25-2024, 11:00 PM Go to last post
  3. Axle Shims
    Started by BJH324JH, 05-26-2017 10:18 PM
    axle, mighty max, shims
    04-20-2024, 06:09 PM Go to last post
  4. Hot Mess
    Started by Rambini50Ra, 04-05-2024 01:27 PM
    04-06-2024, 05:55 PM Go to last post
  5. Heating issues?
    Started by Gremlin50D, 12-21-2021 07:05 AM
    04-01-2024, 12:08 PM Go to last post
  6. hydraulic lash adjusters
    Started by Chichen, 03-29-2024 09:47 PM
    head, hydraulic lash adjusters, valve train
    03-30-2024, 04:06 PM Go to last post
  7. New Head cam sprocket difference
    Started by AlmostMightyMini, 03-24-2024 09:59 PM
    03-25-2024, 06:51 AM Go to last post
  8. Starter Replacement on 1991 2.4L Auto MM
    Started by littleredtrug, 03-18-2024 07:42 PM
    03-20-2024, 12:01 AM Go to last post
  9. 2nd gen shift bushing
    Started by meandmit, 03-18-2024 09:22 AM
    03-18-2024, 09:22 AM Go to last post
  10. 91 3.0 4x4 What is this?!
    Started by EvilNavyGinger, 03-16-2024 10:28 PM
    03-18-2024, 08:42 AM Go to last post
  11. Third Brake Light
    Started by Lil Red, 07-12-2022 09:49 AM
    03-16-2024, 08:10 AM Go to last post
    03-12-2024, 06:03 PM Go to last post
  12. New head, gotta use new rocker arm bearings?
    Started by SwagDaddy, 03-11-2024 06:05 PM
    03-12-2024, 03:36 PM Go to last post
  13. 1984 d55 motor where do you get your parts
    Started by AESHMA, 03-09-2024 05:24 PM
    03-10-2024, 05:51 PM Go to last post
  14. 4WD hub
    Started by Fingers, 03-03-2024 01:16 PM
    03-03-2024, 10:45 PM Go to last post
  15. 1991 Mighty Max 2.4 4G64 No spark
    Started by lmg866, 03-01-2024 03:07 PM
    03-01-2024, 03:07 PM Go to last post
  16. Windshield wiper /washer problem.
    Started by Robic58, 02-12-2024 03:49 PM
    02-29-2024, 07:01 PM Go to last post
    02-25-2024, 12:14 PM Go to last post
  17. Fuse box help
    Started by 147maxx, 02-24-2024 10:30 PM
    02-24-2024, 10:30 PM Go to last post
  18. 1888 Mighty Maxx fuel pump question
    Started by BIGJOE2944, 02-18-2024 09:44 PM
    02-20-2024, 04:18 PM Go to last post
  19. [Unresolved] Gas and Temp Gauges not Working
    Started by Ram50Guy01, 02-17-2024 10:09 AM
    02-19-2024, 02:39 PM Go to last post
    02-19-2024, 06:37 AM Go to last post
  20. G54b timing cover tensioner plate
    Started by Drgawn, 02-13-2024 06:29 PM
    02-16-2024, 07:18 PM Go to last post
  21. 1991 mighty max 2.4L crank no spark
    Started by littleredtrug, 10-07-2023 06:21 PM
    02-14-2024, 10:51 PM Go to last post
  22. 91 Mighty Max wont rev past 2k RPM
    Started by tony2much, 02-07-2024 12:59 PM
    02-11-2024, 01:21 AM Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
