mightyram50.net • View topic - steering stops
steering stops
Stock Trucks.
steering stops
Postby LethalEthan » Sat Mar 27, 2010 10:53 am
So I was under my truck the other day and I noticed there are steering rack stops built into the frame. Is there any disadvantage to adjusting these out a bit for more angle?
LethalEthan
Engine Size: 2.3L
Re: steering stops
Postby Spicoli » Sat Mar 27, 2010 11:19 am
I imagine that if you went to far youd end up busting a tie rod eventually, or something in your steering set up.
Ive debated about doing it to vehiciles before but havent done it to anything yet.
--keRby
Ad Inexplorata
Spicoli
Re: steering stops
Postby LethalEthan » Sat Mar 27, 2010 11:37 am
yeah i was worried about overloading the tie rods. Hopefully someone will chime in. Needing 3 lanes to make a u-turn sucks. hopefully I can adjust them out a bit. Drift angle ftw
LethalEthan
Engine Size: 2.3L
Re: steering stops
Postby camoit » Sun Mar 28, 2010 6:15 pm
You can adjust them. But they need to be the main hard point when turning. Otherwise all the force when turning hard. (like when doing a "U" turn) If you hit a curb you can snap the steering box or rip it off the frame. You can adjust them just make sure there is clearance for the tires, caliper, and some slack to the steering box. Don't use the steering linkage to be the stop or you will bend tie rods. Some times if adjusted too far the steering won't return on it's own. It will just keep going in circles.
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Re: steering stops
Postby LethalEthan » Sun Mar 28, 2010 6:46 pm
thanks for the info, im gonna get under there within the next couple of days and play around with some stuff. I'll put some pics up then
LethalEthan
Engine Size: 2.3L
Re: steering stops
Postby LethalEthan » Wed Mar 31, 2010 7:06 pm
Well I adjusted them out. Gained a half turn on the steering wheel from center to lock. Haven't driven it yet but i'll see how that goes tomorrow
Before
After
LethalEthan
Engine Size: 2.3L
Re: steering stops
Postby LethalEthan » Wed Mar 31, 2010 7:56 pm
nvm driving it tomorrow. flat tire sent me into a drift. I have another tire waiting to go on already so i'll give it a test then.
LethalEthan
Engine Size: 2.3L
Re: steering stops
Postby Bernie Lowmax » Wed Mar 31, 2010 10:09 pm
I think as long as your not at the very end of the adjustment you are ok. If you were to go all the way in, or remove the stops like said above, all the stress would be on flexible things like inner and outer tie rods, this way you have a solid resting point when you go lock-to-lock. Listen to your PS pump when you are lock to lock. make sure it dosent whine or sound like it is laboring very hard. If not i say go you!
Matt Davis
Wilkes-Barre PA
www.ROYALTZ.com
Bernie Lowmax
Engine Size: 4cyl
What year vehicle do you own?: 1995
Re: steering stops
Postby LethalEthan » Wed Mar 31, 2010 10:11 pm
no ps. for me :D
LethalEthan
Engine Size: 2.3L
Return to Stock Front & Rear Supension, Steering.
