motor ?
motor ?
Postby 83powerram50dan » Mon Jan 11, 2010 1:34 pm
i have an 83 dodge ram 50 but the motor barley will turn over with the spark plugs in it but when i take them out it turns over good any one know what could cause that
83powerram50dan
Engine Size: 2.6
Re: motor ?
Postby MightyG54BTMax » Mon Jan 11, 2010 3:42 pm
compression?
MightyG54BTMax
Engine Size: 2.6
Re: motor ?
Postby natureboy » Mon Jan 11, 2010 4:09 pm
Has it ever run? Does it start and run now? More information would help in diagnosing the problem. I would check your timing-if it's off significantly it will turn over slowly. Is the battery charged fully?
natureboy
Engine Size: 2.6l
Re: motor ?
Postby 4cylinders » Tue Jan 12, 2010 7:19 am
hey, how cold is it there, and what oil do you have in it? this unusual cold can cause starting problems.
4cylinders
Engine Size: 2.6
Re: motor ?
Postby 83powerram50dan » Tue Jan 12, 2010 10:20 am
well it messed up an wouldn't run but i got it fixed had it where i could start it if i charged the battery every time so i replaced the starter but i had to go back to my moms to get starter replaced but when i left there was nothing rong with the truck but the starter and when i got back the motor had done locked it self up after i got the motor free ed is when this started happening
83powerram50dan
Engine Size: 2.6
Re: motor ?
Postby 83powerram50dan » Tue Jan 12, 2010 10:21 am
and i just replaced the rod bearing in it
83powerram50dan
Engine Size: 2.6
Re: motor ?
Postby 83powerram50dan » Tue Jan 12, 2010 11:35 am
the crank was fine its just one bearing feel out so i replaced them all
83powerram50dan
Engine Size: 2.6
Re: motor ?
Postby mikewarme » Tue Jan 12, 2010 1:54 pm
YOU CAN'T ASSUME ITS FINE WITHOUT MEASURING IT WITH A PLASTI Guage or a Micrometer. This is the mistake most of you people make... by half assing your enignes and than junking the truck after 10,000 miles cause it blows up.
mikewarme
Engine Size: 2.3
Re: motor ?
Postby 83powerram50dan » Tue Jan 12, 2010 3:58 pm
it was measured my before we put it back togeather
83powerram50dan
Engine Size: 2.6
Re: motor ?
Postby fixerupper10 » Mon Feb 01, 2010 6:18 am
Mikewarme is right. you need to swing by an oriellys and rent out a micrometer.(for crank end play) Plastigauge. its like a really REALLY thin piece of wax string. (pick it up from just about any auto part store. dont know if they sell it in different colors but if they do then get something that you can easily see. check the end play in the crank with the micrometer and look up the specs. if you want then give me the info on the truck, motor, year, all that and i will get the specs and directions for all this stuff. (love having a proffesional repair website for any and all cars!) for the plastigauge. take of the cover for the crank and pull the main bearing holders that hold the crank down. snip a small piece of the gauge off lay it straight on the crank where the bearing will be then tourqe it down then again pull it off and measure how wide the gauge is now(left to right) check specs. if its in spec then its not oversized bearings. if it is then buddy you got way to thick bearings or torqued it down wrong. you need all the specs for this stuff then pm me and ill pull what i can off and make thread with all the engine specs and directions. (directions in this site are sooo much better than chiltons manuals)
fixerupper10
Engine Size: 2.6
Return to Head & Block
Users browsing this forum: No registered users and 8 guests
