mightyram50.net • View topic - oil pump
oil pump
oil pump
Postby m0ta » Sun Jan 30, 2011 7:13 am
Hey guys im having some trouble here with my mitsu, the truck has very noisy lifters n makes a weird sound when i first start it.. im sure its the oil pump but i cant locate one anywhere.. any ideas? thanks
m0ta
Engine Size: 2.0
Re: oil pump
Postby natureboy » Sun Jan 30, 2011 5:52 pm
Rock Auto is a good source for parts.
http://www.rockauto.com/catalog/raframecatalog.php
natureboy
Engine Size: 2.6l
Re: oil pump
Postby m0ta » Mon Jan 31, 2011 9:47 am
Thank you very much bro! anyone know how hard it is to do the oil pump? n what other parts should i replace since its gonna be fix soon?
m0ta
Engine Size: 2.0
Re: oil pump
Postby natureboy » Tue Feb 01, 2011 12:47 pm
I wouldn't say it's hard to change out the oil pump, but it's pretty involved and time consuming. If you don't have a Hayne's repair manual yet, get one. If it's the 2.6 you need to pull the valve cover, water pump, oil pan, distributor, timing cover, timing chain, a few sprockets and finally the oil pump and put it all back together again PRECISELY or you will totally FUBAR your motor. Pretty important to prime the oiling system, too. Definitely NOT the type of repair where you can just "wing it" successfully.
This would be the time to replace a number of hard-to-get-at parts while you've got it open, such as a complete timing set, and the balance shaft bearings and it's chain, guides and gears, or to remove those parts and do a balance shaft elimination kit, if you're so inclined.
natureboy
Engine Size: 2.6l
Re: oil pump
Postby m0ta » Tue Feb 01, 2011 2:31 pm
I have the 2.0 so is it easier than the 2.6 ?
m0ta
Engine Size: 2.0
Re: oil pump
Postby natureboy » Tue Feb 01, 2011 3:06 pm
I did the same repair on my 84 with the 2.0 and the biggest difference is that it uses a timing belt rather than a chain, but it's about the same level of work and difficulty.
natureboy
Engine Size: 2.6l
Return to General Questions.
