time for a new carb
time for a new carb
Postby zipperd50 » Thu Apr 15, 2010 5:21 pm
does any one know the numbers for carbs that will fit a 89 2.6L? like weber 32 36 DFEV? or a different brand
zipperd50
Engine Size: 2.6L
Re: time for a new carb
Postby pennyman1 » Fri Apr 16, 2010 1:44 pm
weber 32/36 dgev/dfav will work, or 34 CEC for emissions for stock or mildly modded. 38 dges "outlaw" for modded motors. Should also change over to an electric pump putting out 4-7 PSI at 50 or above GPH to feed it the right pressure and volume; the stock pump will overpressure the weber and cause it to flood. Putting a pressure reg on the stock pump will just blow the pump out because of excessive back pressure, I know from experience. Get the whole kit with the adaptors for the truck; the jetting will be close.
pennyman1
Postby zipperd50 » Fri Apr 16, 2010 6:04 pm
if i buy a weber carb that was used on something like a jeep or vw i would need to find an adapter plate right? which one would i need to buy i found thick ones and thin ones
if i buy a used weber from ebay that doesnt come with directions would someone on here be able to help me with it?
zipperd50
Engine Size: 2.6L
Postby Ramit » Sat Apr 17, 2010 5:54 pm
Or you could just buy that nice, brand new factory replacement,direct bolt on deal that Mike has for sale.And it would probably cost less than half of what you will spend altogether on the Weber and have none of the headaches of rigging up linkage or rebuilding the used one,or finding other installation parts needed.Just my .02
If you love something, set it free. If it comes back to you it's yours to keep.If it doesn't come back, hunt it down..and kill it
Ramit
Donator
Donator
Postby mikewarme » Sun Apr 18, 2010 12:46 pm
Ramit wrote:Or you could just buy that nice, brand new factory replacement,direct bolt on deal that Mike has for sale.And it would probably cost less than half of what you will spend altogether on the Weber and have none of the headaches of rigging up linkage or rebuilding the used one,or finding other installation parts needed.Just my .02
She is looking for a free one. So his wont help
mikewarme
Engine Size: 2.3
Postby zipperd50 » Sun Apr 18, 2010 1:02 pm
no actualy i am looking for a weber so i wont have to worry about that vacume line mess
zipperd50
Engine Size: 2.6L
Postby jones463 » Sun May 23, 2010 5:45 pm
i just put a 34 dgec on my 82 d-50 and it runs great!! it was only 250.00 for everything at weber 1-866-WEBER
jones463
Engine Size: 2.6
What year vehicle do you own?: 1982
Postby ace of shades » Mon Oct 25, 2010 6:41 pm
Not to highjack a thread but..
pennyman1 wrote:........ Should also change over to an electric pump putting out 4-7 PSI at 50 or above GPH to feed it the right pressure and volume; the stock pump will overpressure the weber and cause it to flood. Putting a pressure reg on the stock pump will just blow the pump out because of excessive back pressure, I know from experience. Get the whole kit with the adaptors for the truck; the jetting will be close.
What all does the electric pump conversion involve? Is it just a block off plate and some wires?
Cut, Weld, Drive http://www.Volksrods.com
ace of shades
Engine Size: 2.6
