head conversion SOHC carb to DOHC injected
Postby Asimonsen » Wed Jul 28, 2010 8:16 pm
how much work would be involved it fitting say a 92 4g63 DOHC NON-turbo head onto an 86 4g63 wide block and just how difficult can it make itself?
it seems to be pretty straight forward to me. Swap head and timeing belt assemblys, install a high pressure fuel pump, ECU, new oil pump.
anything i'm missing?
Asimonsen
Engine Size: 4d55
Re: head conversion SOHC carb to DOHC injected
Postby Asimonsen » Mon Sep 27, 2010 6:54 pm
is it later today yet lol
Asimonsen
Engine Size: 4d55
Postby dmr8x2 » Mon Sep 27, 2010 8:06 pm
i would like to see this too
dmr8x2
Engine Size: 2.4
Postby daytonatrbo » Thu Oct 07, 2010 2:36 pm
bump
wheres the info????
daytonatrbo
Engine Size: 2.0
Postby pennyman1 » Fri Oct 08, 2010 11:37 am
Is it tomorrow yet Mike?!?!?
pennyman1
Postby Spikey1566 » Sun Oct 10, 2010 12:42 pm
wow glad i found this one. gotta see if it works. i dont wanna do a whole swap if i dont have to
Spikey1566
Engine Size: 2.0
Postby rono » Wed Oct 13, 2010 9:23 pm
Are you going to get different pistions or keep the ones already in the block? Doesn't this block Come with 2 valves per cylinder and the valve reliefs for that? Any idea what your compression ratio will be?
rono
Engine Size: none
What year vehicle do you own?: 1995
Return to Head & Block
Users browsing this forum: No registered users and 11 guests
