mightyram50.net • View topic - Tachometer
Tachometer
Tachometer
Postby 85TDW50 » Sat Jan 30, 2010 3:23 pm
Does the Tach Sensor in the VE41 Injector Pump send a signal that a run of the mill (aftermarket) Diesel Tach will read? I was thinking of pulling the Guts out of my Factory Gas Tach (from the cluster in my '84 that's now installed in my '85) and replacing them with the guts from a Aftermarket Diesel Tach.
I originally pulled the Tach out to install a sheetmetal plate to hold the Boost & Pyro Gauges & the Indicator Lights. But i'm going to relocate those elsewhere so i have a factory looking tach in the dash.
Tried a Sunpro (Gas) Universal Tach, sometimes it worked, sometimes it didnt. Dunno if it was a signal difference or not
84 Dodge Power-Ram 50 Turbo Diesel
92 Dodge Dakota 4x4
76 Dodge Ramcharger
74 Plymouth Duster 340
73 Dodge Dart Sport 340
72 Dodge Demon 340
71 Plymouth Duster 440
70 Plymouth Duster 340
65 Plymouth "Formula S" Cuda 273
85TDW50
Engine Size: 2.3L
Re: Tachometer
Postby 85TDW50 » Sat Jan 30, 2010 6:56 pm
MaxD50 wrote:
85TDW50 wrote:Does the Tach Sensor in the VE41 Injector Pump send a signal that a run of the mill (aftermarket) Diesel Tach will read? I was thinking of pulling the Guts out of my Factory Gas Tach (from the cluster in my '84 that's now installed in my '85) and replacing them with the guts from a Aftermarket Diesel Tach.
I have a factory tach for sale, if you are interested.
A Diesel Tach? How much? (it'd be a while, my money is spent on a body for my ramcharger) The main reason i was asking about regular Diesel Tachs working, is that my neighbor (bout a half mile up the road) runs a Diesel Trucking/Equipment Garage and he usually has gauges laying around
92 Dodge Dakota 4x4
76 Dodge Ramcharger
72 Dodge Demon 340
85TDW50
Engine Size: 2.3L
Return to Dash, Guages, Clusters & Interior Lighting
