mightyram50.net • View topic - Speedometer calibration?
Postby netstat » Sun Jan 24, 2010 7:18 pm
Is there a way a way to calibrate the speedometer in a 2nd gen MM?
after installing my new gauge setup my speedo appears to be about 10 mph off. needle placement looks correct, so i am assuming that would only account for 2-3 mph tops.
when I was swapping the speedo element between clusters I noticed a small lever type mechanism attached to the spring for the speedo gauge. Is this an adjustment of some sort? It seemed a little loose while I had access to it so I can't imagine it would be able to keep a setting if that actually is it. Is the looseness in it a self adjustment of some sort that maybe it will just center itself over time?
Any help is appreciated.
Btw, that looseness I described is guaranteed to be the way it is supposed to be because both clusters seemed to have the same tension on that part.
netstat
Engine Size: 2.4L
Re: Speedometer calibration?
Postby netstat » Sun Jan 24, 2010 8:57 pm
found the answer ... it is that stupid lever thing way inside the cluster :(
netstat
Engine Size: 2.4L
Postby 77amc » Sun May 16, 2010 12:50 pm
Interesting that you had this..
When I swapped the 2.6 trans back in, and with the yota rear (should be close to the starion gear ratio) I put a starion speedo gear in the trans but didn't think to see if it did feel like the speed that was showing.
The gear was a different pitch..
E
77amc
Return to Dash, Guages, Clusters & Interior Lighting
