mightyram50.net • View topic - dashboard swap?
dashboard swap?
dashboard swap?
Postby MMaxx94 » Wed Jan 20, 2010 7:50 am
How hard is it to do a dashboard swap?
i'm looking to put a 99-04 style Mustang dash in my MM [its all going with a Mustang theme, the seats are also from an 01 Mustang]. its the same size door-to-door per say, but the curve by the windshield is way different. whats the best way to modify it to fit? Also, what kind of work am i looking at as far as the steering wheel and gauge cluster? we have no a/c or heat so that won't cause us any issues.
94 Max
<Under ConsTrucKtion>
00 Dakota 4X4
V8 Magnum Mud toy =)
04 Mustang [DD]
true dual exhaust, rims, custom audio & interior, lowering springs
http://www.myspace.com/XoStangBabyXo [add mee]
MMaxx94
Re: dashboard swap?
Postby pennyman1 » Wed Jan 20, 2010 10:20 am
The easiest way to swap is to get a fiberglass repro dash and recurve it to fit the MM dash curve. If thats not an option, then you could make a steel plate to fill the difference, then make filler pieces painted to match that tie into the interior, like some cars have.
Re: dashboard swap?
Postby MMaxx94 » Thu Jan 21, 2010 6:44 am
thx =)
94 Max
00 Dakota 4X4
04 Mustang [DD]
MMaxx94
Return to Dash, Guages, Clusters & Interior Lighting
