mightyram50.net • View topic - bezal for radio removal
Postby payrion » Fri May 28, 2010 7:08 pm
im having a hard a** time getting that radio bezal off? what am i missing?????????????????
payrion
Re: bezal for radio removal
Postby Alan » Sat May 29, 2010 6:27 am
What year model truck do you have? If it is 1987-95 there are four screws, one just inside the glove box and three along the top edge of the bezel. Also, the bezel has raised plastic edges that hold the bezel in at the top and bottom. You will have to slide a thin screwdriver in between the top of the bezel and the dashpad to release these plastic edges. I have used a craftsman gasket scraper because it has a wide thin blade. There are two at the top and at the bottom if I remember correctly. Undo the bottom first to make it easier. Hope this helps.
Alan
Engine Size: 2.4
Postby payrion » Sat May 29, 2010 6:43 am
ok thanks alot, i have the same as you, i missed the glove box one... ill give it a try later.
payrion
Return to Dash, Guages, Clusters & Interior Lighting
