Location of Overdrive Solenoid
Postby Koprnkc » Sat Jan 16, 2010 7:36 pm
So, notice that my power ram 50 w/auto transmission was not shifting into overdrive. Figure the overdrive solenoid has shot craps. Now, just want to verify, is this solenoid located on the driver side, on the transmission, under the vehicle? Or is the solenoid mounted somewhere else?
Thanks for the help guys
Koprnkc
Engine Size: 2.6L
Re: Location of Overdrive Solenoid
Postby LethalEthan » Sat Jan 16, 2010 9:50 pm
normaly its the overdrive relay that goes out. I think its on the driverside kick panel up by the firewall. Mine was a round plug with a metal cap on it.
LethalEthan
Engine Size: 2.3L
Postby pennyman1 » Sun Jan 17, 2010 6:30 pm
There is a sensor on the intake manifold that tells the tranny the truck is at operating temp- if it fails, no overdrive. If you ground that wire , then the o/d works all the time.
Postby Koprnkc » Mon Jan 18, 2010 6:41 am
Thanks for the help guys. I know one way to check for the bad relay is to turn the key to the on position and listen for a click down by the kickpanel when pressing the OD button. I will try that first, and work my way from there.
Koprnkc
Engine Size: 2.6L
Postby payrion » Thu May 06, 2010 5:21 pm
i know this is old but... My 91 2.4 l auto is doing th same thing, i feel shifts up to 3rd then no OD, can someone explain the relay and or what i need to look for....
payrion
Postby payrion » Thu May 06, 2010 5:50 pm
nevermind, i found the unplugged wire on the engine, grounded it and BAM i have OD, it cool.....
payrion
Postby wedwards » Mon Jul 26, 2010 11:30 am
payrion wrote:nevermind, i found the unplugged wire on the engine, grounded it and BAM i have OD, it cool.....
could you post a pic or say right where it is
wedwards
Engine Size: 2.4
Postby payrion » Mon Jul 26, 2010 2:07 pm
i didnt actually find the part itself, just an unplugged ground wire in front of the throttle body, i grounded it and BAM, over drive.
payrion
Return to Transmission.
