Manual Trans compatibility question
Postby Chauron » Mon Sep 28, 2009 8:31 pm
I'm sure this has been talked about already but is the manual transmission from a 90 2.4L the same as the manual from an 88 2.0L? If not, are they interchangeable?
Chauron
Engine Size: 2.4L
Re: Manual Trans compatibility question
Postby Johnboy72 » Tue Sep 29, 2009 4:08 am
No, the 2.4, 2.6 and believe 2.0 (auto) are all wide blocks. The 2.0 5spd are narrowblock. Believe if you measure the two bottom bellhousing bolt holes that will tell ya the answer. Someone correct me if I'm wrong but the narrow block is 12.25" and wide block is 13.25". If no one answers, I have both transmissions and can measure after work. I can measure both blocks too.
Johnboy72
Postby Chauron » Tue Sep 29, 2009 1:17 pm
Ah ok, I'll take a look at mine and get measurements.
Chauron
Engine Size: 2.4L
Postby Spicoli » Tue Sep 29, 2009 4:19 pm
Johnboys right.
--keRby
Ad Inexplorata
Spicoli
Postby pennyman1 » Tue Sep 29, 2009 5:41 pm
But all manual trannys are wide block, so a manual 2.4 should fit a manual 2.0. the clutch disc and pressure plate may be different though
Postby DroppedMitsu » Tue Sep 29, 2009 7:09 pm
No pennyman a 2.0L with a manual 5 speed tranny is NARROW block.
To the original poster, no they are no the same and will not interchange because the 2.4 is a wideblock and the 2.0 manual tranny is narrowblock as Johnboy stated
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Postby TotallyBalistic » Tue Sep 29, 2009 7:17 pm
what are you needing a trans for?
595
TotallyBalistic
Good Times
Good Times
Postby Chauron » Wed Sep 30, 2009 1:34 pm
I recently pulled an 88 Max out of a field for $350, the guy said it was really hard getting it from 1st to 2nd and that it would grind doing it.... I'm thinking its a synchro issue but I'm not sure, nor have I had the chance to experience the problem myself. We just got it running Tuesday but it needs an idler arm before I'm gonna attempt to drive it.
There's a junkyard around here that I've heard will sell any transmission for $90 with a 30 day garantee, if you pull it yourself.
Chauron
Engine Size: 2.4L
Postby Johnboy72 » Wed Sep 30, 2009 2:39 pm
That's a good price. Cash N Carry in Savannah charged me like $125 core included and believe they have a 30 or 90 day warranty. www.iluvused.com
Johnboy72
Postby pennyman1 » Wed Sep 30, 2009 5:54 pm
Even I can learn something- I may have known about the 2.0 5 speed being different, but I didn't know that its a narrow block as well.
Return to Transmission.
Users browsing this forum: Google [Bot] and 2 guests
