What Ford Trans is this guys??
Postby 77amc » Thu Sep 16, 2010 4:17 pm
Well I finally got my Hornet home to the shop and pulled the motor/trans. At some point the p/o did a ford tranny swap that can fit the AMC bell-housing with little fab.
BUTm I don't know fords at all, and need some help identifying this trans.
Lets see if I can post a pic of it here.
[img][IMG]http://img256.imageshack.us/img256/1408/hornetteardown910006.th.jpg[/img][/img]
[img][IMG]http://img201.imageshack.us/img201/2840/hornetteardown910010.th.jpg[/img][/img]
Thank you, Errol
77amc
Re: What Ford Trans is this guys??
Postby camoit » Thu Sep 16, 2010 4:21 pm
Any numbers on it?
How many forward gears? 3,4,5,6
Oh and I dropped the picts up. You have some code off. You have html tags that are screwing it up.
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Postby pennyman1 » Thu Sep 16, 2010 5:18 pm
x2 on the top loader - all manual trannys for AMCs in the 60s up were ford toploaders except for the t-10s in the high power cars
Postby 77amc » Thu Sep 16, 2010 6:52 pm
Thanks for the uploading sir..
Pennyman: Really..? I've read that the 4,6, some 8's used the Saginaw 4spds and some of those were the aluminum bodied ones. (those didn't like much torque) BUT then again, they used the parts bins from most every maker out there at the time.
I'll have to dig out my books and shop manuals. I was immersed in them years ago but since getting into the Mitsubishis, I've forgotten lots.
SO, any info on the "top-loader" trannys?
It looked to be a corse spline input shaft, but the clutch looked fairly stout..
Here's a site I found on them.. I guess its' not a top loader.
http://www.davidkeetoploaders.com/
Of course, i didn't write down the casting #'s and i'm too tired to go back out to the shop..
I did pick up some aluminum cleaner that has a acid base in it for some other projects, so maybe I'll give it a good scrubbin and get all the markings/#'s off of it.
Thanks again fellas.
Errol
77amc
Postby TotallyBalistic » Thu Sep 16, 2010 7:15 pm
i dont remember what its called but i seen one of these behind a nasty 302 in a rat rod...the guy had loads of problems with shift forks binding in it, new and used
595
TotallyBalistic
Good Times
Good Times
Return to Transmission.
Users browsing this forum: No registered users and 9 guests
