mightyram50.net • View topic - Clutch wont disengage
Postby joldfort » Mon Aug 09, 2010 12:29 pm
This is my first post, i have an 85 mighty max and have never had any problems with the clutch, well ive been sick the last couple months so its been sitting. anyway i got in it this morning and it started fine as always but wouldnt take any gear. i can start it in gear and it pulls good but the clutch wont release. its a 4 speed and the cable is fine, ive never heard of a clutch going out on a parked truck... anyone have any ideas?
joldfort
Re: Clutch wont disengage
Postby joldfort » Mon Aug 09, 2010 12:33 pm
PS is there any small adjustments i can make myself, im not healthy enuff to tackle anything major like replacing the clutch and ive been outta work a while so moneys tight. any help would be greatly appreciated
joldfort
Postby camoit » Tue Aug 10, 2010 9:04 am
While driving in 1 or 2 you can also try pushing and holding the clutch in then slam the gas to the floor on and off on and off. The torque might break it free. Let us know how it works out.
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Postby joldfort » Tue Aug 10, 2010 11:05 am
Thanx alot maxd50, worked like a charm
joldfort
Postby 83L200 » Wed Aug 11, 2010 9:50 pm
good old mike, were would we be without you
83L200
Engine Size: 4G63
Postby camoit » Mon Aug 16, 2010 12:23 pm
What worked? Slaming on the brakes or jaming the throttle??
camoit
Admin
Admin
Engine Size: 2.6L
Postby joldfort » Mon Aug 16, 2010 2:23 pm
Slamming on the brakes worked before i could try anything else
joldfort
Return to Transmission.
