Turbo
Turbo
Postby shield88mm » Wed Jan 20, 2010 8:41 am
I am looking to add a turbo to my stock 88 MM 2.0
Are there any donor vehicles that could provide a bolt on solution?
Has anyone done this?
shield88mm
Re: Turbo
Postby mackmitsubishi » Wed Jan 20, 2010 9:48 am
there is not 2.0 bolt on turbo except the conquest/starion 2.0 SOHC motors but that was only available in OZ or new zeland.
Now one possible swap may be from a Mitsubishi cordia 1.8.. Its a smaller displacement and its in a FWD configuration but it should be bolt on. depending on where you are i know of one cordia turbo in PA that has the entire engine.
mackmitsubishi
Re: Turbo
Postby 83L200 » Wed Jan 20, 2010 10:41 pm
4g63t
83L200
Engine Size: 4G63
Re: Turbo
Postby netstat » Thu Jan 21, 2010 7:06 am
I thought there was some semi-serious changes that had to be made to fit the 4G63T
netstat
Engine Size: 2.4L
Re: Turbo
Postby Spicoli » Thu Jan 21, 2010 4:14 pm
Thermostat housing the big deal.
--keRby
Ad Inexplorata
Spicoli
Re: Turbo
Postby 83L200 » Thu Jan 21, 2010 10:39 pm
not serious changes there is a few minor ones but its worth it.
83L200
Engine Size: 4G63
Re: Turbo
Postby crvtec90 » Fri Jan 22, 2010 2:44 pm
I know a guy who made his own manifold to boost his 2.4. It worked well for a while but eventually it would not hold boost pressure. He had finally narrowed it down to the shaft seal for the throttle plate. It was pushing 8-10 pounds I think. He tried changing out the throttle body nuerous times but no fix.
Drive it like u stole it
crvtec90
Users browsing this forum: No registered users and 7 guests
