mightyram50.net • View topic - 12 Volt Glow Plugs
12 Volt Glow Plugs
12 Volt Glow Plugs
Postby 85TDW50 » Sat Sep 12, 2009 10:31 am
Anybody know where i can find a set of 12 Volt Glow Plugs for my '85 Power-Ram 50 4D55?
I've searched online for days, tried cross referenced numbers, i can't seem to find anything. The one site i did find them (thanks to a friend on another board for helping me) could no longer get them (NGK Y-115T1 Silver Tops) because they're out of production. I also tried all the local Auto Parts Stores (Advance, Napa, Carquest, Federated), nobody could find them there either
I'm running a Ford Starter Solenoid/Relay & a Momentary On Toggle Switch for my "Glow Plug Controller" so thats why i need 12 Volt plugs
84 Dodge Power-Ram 50 Turbo Diesel
92 Dodge Dakota 4x4
76 Dodge Ramcharger
74 Plymouth Duster 340
73 Dodge Dart Sport 340
72 Dodge Demon 340
71 Plymouth Duster 440
70 Plymouth Duster 340
65 Plymouth "Formula S" Cuda 273
85TDW50
Engine Size: 2.3L
Re: 12 Volt Glow Plugs
Postby 85TDW50 » Sat Sep 12, 2009 10:52 am
If i remember correctly, the ones Rock Auto listed were 6 Volt Plugs, i tried 6v plugs in it. And being new to diesels at the time i had no idea there were different voltages, i ended up killing them.
A member on another forum i frequent suggested using a Chrysler Ballast Resistor to drop the voltage down, but neither of us is sure if the Ballast will handle that kind of a load.
92 Dodge Dakota 4x4
76 Dodge Ramcharger
72 Dodge Demon 340
85TDW50
Engine Size: 2.3L
Postby BCDieselD50 » Sat Sep 12, 2009 1:59 pm
BCDieselD50
Postby wrngwae » Mon Sep 14, 2009 3:38 am
i run the stockers on a push button system and have had no glowplug issues ever!!!!!!!!!!!!!!!!! even though i was told it wouldnt last a couple months.....
or Chinese parts!!!!
764  768
wrngwae
Super Mod
Super Mod
Engine Size: 2.3
Postby Spicoli » Mon Sep 14, 2009 6:29 pm
wrngwae wrote:i run the stockers on a push button system and have had no glowplug issues ever!!!!!!!!!!!!!!!!! even though i was told it wouldnt last a couple months.....
Who ever would have said that????? Hahahaha I have a funny feeling who
--keRby
Ad Inexplorata
Spicoli
Postby wrngwae » Tue Sep 15, 2009 3:22 am
you would be correct Kerby,,,,,,,,,,,,,,,,,,,,,,,,,,cough cough,,,,,,,,,,,lol
764  768
wrngwae
Super Mod
Super Mod
Engine Size: 2.3
