Grounding the wire while timing? Help Please
Postby samario1984 » Sat Dec 11, 2010 4:35 pm
Truck is a 1994 2.4 l I just fixed the timing belt which was off one tooth. Per my manual i am supposed to ground out a wire in order to time it correctly. Unfortunately my manual was not very specific and I believe I grounded out my fuel pump check wire instead. The truck will no longer start but still has spark and i did some research in the manual it looks like i might have grounded the wrong wire! So 2 questions the first being where is the correct wire to ground? The second anyone know what the wire on the passenger side of the truck above the fender goes to? I still have spark so I am thinking something fuel related!
samario1984
Engine Size: 2.4
What year vehicle do you own?: 1994
Re: Grounding the wire while timing? Help Please
Postby samario1984 » Sat Dec 11, 2010 8:47 pm
Ok, Thanks for the advice i hope it was just the fuel pump relay i would be mad if it wound up costing me 300 bucks for a new ecm!! Now on to the right wire does anyone know which one is correct?
samario1984
Engine Size: 2.4
Postby camoit » Mon Dec 13, 2010 7:03 pm
there might be a manual on line eather in our manual section or on the net. Sorry I don't have info you are looking for. Maby the dealer can get you a print out. Ask the parts guys first.
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Postby Rahtid » Tue Jan 25, 2011 1:07 am
There should be a black connector on the fender. You have to let the truck get to operating temperature before setting timing
Rahtid
Engine Size: 2.4
