drop spindle question
Postby austin » Sat Sep 18, 2010 3:14 pm
I have a 86 ram 50, and I would like to get 2 inch drop spindles for it. All I can find are drop spindles for the 87-up. will those work with a little modding? Or does anyone know where I can get drop spindles for an 86?
Guns kill people like forks kill people.
austin
Re: drop spindle question
Postby pennyman1 » Sat Sep 18, 2010 6:03 pm
They will work but you either have to lose the dust shields or cut them to allow for the relocation of the caliper on the spindle. If you choose, you could change over to the 87 up rotors and calipers to give you vented rotors and upgraded performance brake pads. I have the AIM spindles and have checked out both these options, so no guesswork is involved here.
Postby MaddMaxx87 » Tue Oct 26, 2010 11:28 am
Do u need to upgrade from 15" wheels to 16"+ when using these drop spindles??..
Thanks
Something of something is never as good as anything of anything..
MaddMaxx87
Postby pennyman1 » Sun Oct 31, 2010 3:31 pm
I am running 16" wheels so clearance is not an issue for me. If you are running the stock wheels/offset then yes they would rub, especially the 14" with 5" backspace.
Postby austin » Fri Nov 26, 2010 9:12 pm
Are those drop spindles as strong as the stock spindles? My truck will see a lot of hard driving, I want it to hold up.
austin
Postby pennyman1 » Sat Nov 27, 2010 8:35 pm
They should as long as you drive it like a normal person; I wouldn't hop a truck with drop spindles.
Postby austin » Wed Dec 01, 2010 12:25 am
No, more like racing. I want to be able to drive my truck at 100% and not worry about the wheels coming off.
austin
Postby pennyman1 » Wed Dec 01, 2010 7:29 am
Either Belltech or AIM spindles should be good for that.
