mightyram50.net • View topic - 86' Power Ram 50 Project: Desert Hunter
Forum rules
Postby Acuta73 » Tue Nov 16, 2010 11:44 am
Kind of a long back-story on this one.
I've owned a 1986 Dodge Power Ram 50 since 1992, for many years it has just been my huntin' and haulin' rig, my wife had the family grocery-getter. Back around 2003, I re-built the engine from the ground up, twice, actually. First time around I managed to get an oil ring UNDER a compression ring while seating a piston. Do not ask me how, it still bugs me to this day. Needless to say, this did bad things to my #3 cylinder wall. Short-block rebuild take #2 involved a local engine shop. Here's where it kinda gets interesting. Unbeknownst to me, the old fella that owned the shop ONLY did SCCA race car engines...I dunno why in the hell he did mine, but he did. I can only assume he felt sorry for me. I found out about 2 years after he retired about the race bit. It explains a few things...
When I got my short back, I asked what all he had to do. He bored her .060-over (had to due to the cylinder scoring), dropped in flat-top 3-ring pistons, line bored it (including the stock balance shafts), balanced the crank, and pressure tested the core (new bearings should be a gimme, here). All for? $500. No joke, no lie. Part of the reason I just can't get myself to part with the old beast.
Well, about 5 years ago I had her up hunting Elk. We got some crazy weather. Days 1 and 2 were 70+ degrees, then it started snowing, by day 4 it was -2 and snowing HARD. We had to bug out a day early with a forecast of 4' in 24 hours. Dunno what happened, but the carb never was the same (water choke...hmmm...). Anyway, a couple weeks ago the old Mikuni started acting up again. Didn't feel like dealing with it myself (mid-80's Japanese carb/emissions...need a PHD in engineering to work on em), so I took it to a local. He said the choke-breaker was toast (no big surprise). I was fed up with rebuilding that carb (this would have been the 5th time) so I bought me a new toy:
Weber 38 DGES (synchro)
Added a Carter P4070 fuel pump on a kill switch to keep it happy (no pictures, I just didn't think about it)
I don't have a "before" pic of the engine compartment, but I can tell you, it's one HELL of a lot emptier, now!!
You can see my DIY blanking plate for the old mechanical pump here:
She's currently in the shop for a final tuning and to fix a couple of "oops" of mine. I can set timing by ear 99% of the time, can't adjust a carb to save my life...
Well, fate pushed me into starting this earlier than I had wanted (had intended on starting early 2011 after I got 2 computer builds and case mods done), I am going to be getting to hunt Pronghorn next August after a 13 year wait. I've intended to make this truck into a custom hunting/fishing rig for over a decade now. Well, that time has come.
Well, what does this beast look like now?
Ugly...but with a damned good engine (and rebuilt tranny/transfer)!
The Plan:
1. Flip the rear axle and crank the torsion bars up
2. New distributor and MSD ignition system (better fuel mileage and more pulling power) Ignition Control - Coil - Wires + Bosch Platinums
3. New dash and updated instrument cluster (to include Tach and phone mount for nav and MP3) (mod)
4. Sound system (of course)
5. Custom modular headache rack for my canoe and other toys (mod)
6. 3" body lift
7. Full Poly bushing kit
8. Bed seats for 2 (removable)Seats - Mounts - Harness x2 + mounting frame (custom weld job)
9. Receiver hitch (for boat/utility trailer)
10. New bumpers
11. LED marker/brake/turn (mod)
12. deep cycle on isolator circuit (for off road lights and an inverter)
13. Ford Ranger HID headlights (mod)
14. Custom Grill (mod)
15. New windows and a sunroof (sunroof mod)
16. Bodywork (to fix some cancer and a large dent where a little girl backed into me)
17. Second fuel tank (provision already exists in frame. Just need a switch, tank, sending unit, and filler) (mod)
18. 30" or 31" Wildcat EXT (same tires it has now, only larger) and 2x spares
19. The tough part...paint job. I want this pattern: Digital Desert Camo (all exposed metal parts except wheels, grill, bumpers, and kick panels. I think there's a law somewhere that says old 4x4 are REQUIRED to be painted camo)
20. 2 Jockey Boxes to replace the 1/4 panels on the bed:
Passenger side box will house the deep cycle and inverter, the split rear window I grabbed off a MM in the junk yard years ago. Still need a lock for it...
21. Vanity plates to read: DUKTRUK (I'm a duck hunting fanatic)
22. Off-road and cargo area/backup light setup
23. Mirrors of some variety
24. Warn manual locking hubs
25. POSSIBLY a winch, but I doubt it.
26. General mechanical work (brakes, full lube order, and a rear diff. input seal)
27. Possibly a 2-plate clutch (if I can find one)
28. Replace the existing 12 valve head with an 8 valve ported and polished (current head includes "jet" valves for emissions...an afterthought, if ever there was one)
29. Considering losing the mechanical fan and clutch for electric
Project Completion: July 2011 (I hope...)
This will be a SLOWW work in progress, but the end product will be well worth it: A small, powerful pickup to get me where I need to go in the extreme back country, and still haul my boat to the marsh/river/bay for some feeshin/gunnin/crabbin. Pulling stumps and bouncing off trees will still be doable. This is no race truck, it's a utility vehicle (in the truest sense), but I want/need power to haul toys and gear around the state. My Dad and his buddy both have shiny 1 and 3/4 ton trucks they won't take on anything worse than all-weather gravel roads, mine is the "abuse it" rig to get to remote areas and to haul dead critters back out.
Very much up for any suggestions, of any variety.
Acuta73
Engine Size: 2.6L
Re: 86' Power Ram 50 Project: Desert Hunter
Postby Acuta73 » Tue Nov 16, 2010 11:56 am
Well, just got it out of the shop.
Good news: carb is dialed in, though still wants to diesel a little at shutdown (I think the tech got a little idle speed happy, no worries)
Bad news: Found the issue with backfiring (didn't mention it before, thought it was just an adjustment issue). Turns out I have to replace my intake manifold gasket. They quoted me $450 to do it! :shock:
Guess I know what I'm doing this weekend... :angry-banghead:
Acuta73
Engine Size: 2.6L
Postby pennyman1 » Thu Nov 18, 2010 6:57 pm
Go onto ebay and get an anti dieseling solenoid for the carb - JoeTLC carries them for about $20. 450 for an intake gasket - what a deal, for them!!! What maroons!?! (Bugs Bunny ref)
Postby Mojave Magic » Sat Nov 20, 2010 5:57 pm
http://cgi.ebay.com/ebaymotors/Weber-Ca ... ccessories
This was the one that I got, but it didn't fit the 32/36 DFEV. Someone here said it would work, but they were wrong. The 38 DGES was specifically mentioned in the listing though. I think it was $21 and change after shipping. I sold my truck and still have the solenoid sitting here, I'll do $15 shipped if you want. I stuck 12v to it and it works fine.
1988 Power Ram 50 75k miles SOLD :(
1998 Ram 3500 quad cab SLT Laramie 5.9 12v Cummins
Mojave Magic
Postby Acuta73 » Sat Nov 20, 2010 10:30 pm
Replaces the primary jet, hmm. I'll look into more and decide. I've got everything running better after farting with it a bit more. New ignition should make things better yet.
On the ignition note, I saw someone post about using a different distributor (Mazda, I think?). Going with the MSD ignition, is there a decent upgrade for the stock? I have to replace it anyway, but was just going to drop in an OEM reman. Did notice MSD doesn't make a rotor and cap for the stock, but I don't see that as much of a big deal.
Acuta73
Engine Size: 2.6L
Postby pennyman1 » Sun Nov 21, 2010 7:37 pm
I've been running an original MSD Blaster coil, circa 1981, and a set of Nology wires with NGK platinum plugs. Can't run an aftermarket ignition box with Nology wires, they interfere with each other. Ran an MSD 5 box before the Nology wires, didn't get the zip I thought I would; an MSD 6AL would be a better choice for these trucks. It's very hard to find aftermarket caps for the 2.6; the last one I found was an Accel cap and rotor, but that was in the early 90's.
Postby Acuta73 » Mon Nov 22, 2010 2:10 am
Yeah, the 6AL looks like a good choice, particularly for 4-low operation with the rev limiter. Gonna go with the fat wires and probably the Blaster2 coil (with ballast, depending on what the support D-bags finally reply with), might end up with the SS coil. Still leaves the dizzy, and cap/rotor to deal with, consensus says NGK plats with .05-.055 gap?
Got the beast on the interstate today, 65mph@~15mpg. I think better with new ignition (should be able to lean it a bit). No hiccups and no dieseling once the damned thing idled down at max operating temp.
Acuta73
Engine Size: 2.6L
Postby Acuta73 » Tue Nov 23, 2010 9:02 am
Fuel mileage just sucks, I need an ignition fast and MSD seems to only be interested in pushing on me the most expensive compatible unit they have (6AL-2, and I don't even own a laptop...). I'm willing to spend good money on their product, and they just want to "sell" me. Morons...
I found that dieseling goes away once I reach operating temps, bugger is, I only drive 3 miles to work. Engine really doesn't have a chance to fully warm up. I can either spend the $20ish on a choke breaker solenoid, or learn to just live with it. Still hoping for an answer on the distributor, too. = )
Acuta73
Engine Size: 2.6L
Postby 4doorciv » Wed Nov 24, 2010 5:41 pm
Did you try using seafoam in your gas tank? Maybe it's carbon buildup causing your truck to diesel.
-Ryan-
4doorciv
Engine Size: 4g63
Postby pennyman1 » Wed Nov 24, 2010 5:47 pm
Have you rejetted the carb to better match the engine? On a mostly stock engine, the mileage wil be bad. The 38dges is not an economy carb; its for power and lots of fuel delivery. The plug choice and gap with an aftermarket ignition will help make it run its best, but you're drowning the motor with fuel. No ignition will cure that. Set the timing to 10 Degree btdc to cure the dieseling.
Return to All 4WD Trucks
