mightyram50.net • View topic - Divorced T-Case...
Divorced T-Case...
A place to post build threads for Might Max Trucks.
Forum rules
Divorced T-Case...
Postby Mighty6 » Wed Dec 02, 2009 9:51 pm
Can someone give me a good explanation of dirvorced tcases and trannies? I know its possible with enough money; but if no divorced t-case mates up to a tranny... how hard/expensive is it to get it to mate?
Mighty6
Engine Size: 6G72
Re: Divorced T-Case...
Postby marlin3030hntr » Sat Feb 06, 2010 8:50 am
well what are you looking to find one for?? i mean what side is your pumpkin on in the front?? for chevy and dodge all had divorced setups as well as international did early chevy(up to 88 or any 1ton up to that i believe), dodge(with the t18, t19 or np435 & 727) and all international(travelall's with 727, t-18 or t19 that were 3/4 or 1 ton)those are all passerger side. side ford was on the driver side(np435, t-18, t19, c6 and i believe early truck aod's were divorced i believe) and why do you want the divorced setup?? sometimes its more or a pain than its worth other times makes sense
-80 Arrow Truck(daily driver)
-64 Scout SOA conversion w/ chevy v8 and th350 swap(4x4 hunting rig)
-77 f100 w/ 400m(ass haulin pickup)
-67 Plymouth Belvedere orig. 318(8 yr project car and going)
-86 Mustang GT(weekend cruiser)
marlin3030hntr
Postby TotallyBalistic » Sat Feb 06, 2010 2:16 pm
i like a divorced t-case in a truck thats got alot of lift, you can drop it down and reduce driveshaft angle. i plan on putting one in my 4x4 later down the road
595
TotallyBalistic
Good Times
Good Times
Postby marlin3030hntr » Sun Feb 07, 2010 6:53 am
i dont ever like driopping anything that has to do with the tranny or tcase if i dont have to my scout has 3ft of center frame clearence and thats cuz i kept the engine tranny and tcase up high where thay should be and twisted my pinion up(not with shims i moved the springpads cuz its a spring over now) on the front and back, the front not as much ofc because if the steering but didnt need to as much because have an auto in it and so my front shaft is longer that used to be when i had the stick in it.
marlin3030hntr
Postby TotallyBalistic » Sun Feb 07, 2010 9:37 am
you lift a truck high enough to put 44's on it and you gotta do more than adjust some pinion angles
595
TotallyBalistic
Good Times
Good Times
Return to Mighty Max Trucks
