My 87 white mits build
(1987-1996)
Forum rules
Re: My 87 white mits build
Postby laidoutmits » Fri Oct 01, 2010 2:58 pm
next I took of the bottom of the pocket that was in the way of the lower control arm.
laidoutmits
Postby laidoutmits » Fri Oct 01, 2010 3:04 pm
with that of the pocket being left and the spindle still being able to tuck an 18" I started making some cups to mount bags to but not knowing exactly what I needed I made some trim to fit universals.
laidoutmits
Postby laidoutmits » Fri Oct 01, 2010 3:08 pm
fitting hole needed to be bigger but that can be done with a step bit. Next I started reverse mount mocking to the U C arm mount.
laidoutmits
Postby laidoutmits » Fri Oct 01, 2010 3:14 pm
and now I can remount the U.C. arm.
Image'
laidoutmits
Postby laidoutmits » Fri Oct 01, 2010 3:20 pm
next I tried to set the spindle at slammed height but I ran into a binding issue and had to pie cut the upper and just give a relief cut on the lower arms
laidoutmits
Postby laidoutmits » Fri Oct 01, 2010 3:29 pm
and there you have it tuckin a 25 " diameter tire . (25" tire half of diameter is 12.5" plus 12" ground frame hieght and u got 24.5" then I added a 1/2" to get 25")
laidoutmits
Postby laidoutmits » Fri Oct 01, 2010 3:33 pm
next I realized that I wasn't going to be able to get the bag in the spring cup area and cut it off
laidoutmits
Postby laidoutmits » Fri Oct 01, 2010 3:38 pm
Next was to start making new top bag plates.
laidoutmits
Postby laidoutmits » Fri Oct 01, 2010 3:43 pm
and the beginning of the bottom mount to
laidoutmits
Postby camoit » Fri Oct 01, 2010 4:52 pm
Why did you go with ball joinsts? I would have just went with Uniballs. more movement.
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
PreviousNext
Return to 2nd Generation
