mightyram50.net • View topic - Need brake and clutch pedal assembly
Need a part? Post in here to see if someone has it.
Forum rules
All Wanted Item Are Automaticly Removed After 60 Days.
Postby cru808tech » Sun Feb 20, 2011 2:58 pm
I need a clutch and brake pedal assembly for my 88 DODGE ram 50. I need it to be HYDRAULIC TYPE. I have put a 89 mitsubishi sterion engine and 5sp., trans in my truck and can't find an assembly to fit. Anyone have an idea on where to get one or what can I do to make this work??
cru808tech
Engine Size: 2.6L
Re: Need brake and clutch pedal assembly
Postby mikewarme » Mon Feb 21, 2011 5:27 pm
Either the set-up from a raider montero will work 83-92 or a 83 85 diesel pickup ram 50 or mighty max
mikewarme
Engine Size: 2.3
Return to Wanted
