mightyram50.net • View topic - WTB: Driveshaft carrier bearing/support bearing
Need a part? Post in here to see if someone has it.
Forum rules
All Wanted Item Are Automaticly Removed After 60 Days.
Postby DarthWookie » Sun Aug 15, 2010 10:12 am
Hey guys, I recently crawled under my truck to fix a wire and noticed that my driveshaft carrier bearing is pretty much a goner. I figured I'd post up here to see if maybe one of you might have a good one laying around that you'd be willing to sell me, or might know of a cheaper, cross compatable unit from a different vehicle, cuz around my neck of the woods they run from 90 to 125 bucks, and I just cant afford that kind of bank right now. Any and all help will be appreciated!
where the hell are my PANTS!?!?!?!?
DarthWookie
Re: WTB: Driveshaft carrier bearing/support bearing
Postby camoit » Sun Aug 15, 2010 10:10 pm
call drive line service of Forest Park, GA 30297-3560 (404) 361-0475. They might be able to help you..
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Postby ARCHINSTL » Tue Aug 17, 2010 10:50 am
Let us know your result, whether from the mentioned source or another. I need one as well.
AND - maybe a pictorial when you replace it? Maybe you'll discover an easier method than that shown in the FSM.
Tom M.
ARCHINSTL
Postby 77amc » Mon Aug 23, 2010 9:46 pm
I used a carrier bearing from a talon. Cut the housing, pryed it apart (of each) and swapped in a known good one, compressed with a C-clamp and rewelded it up.
Granted, I had the talon bearing already.. My max had 225k on it, shredded rubber around the bearing and wobbled all over while still bolted in. Prev owner and my self would've never known it was bad unless I tood a look-see at it.
Even taking the shaft apart to make it fit a yota rear, the Ujoints looked pretty good!
It sure was cheaper than paying over 80$ for a new one.
E
77amc
Postby fubar4774 » Sat Aug 28, 2010 4:45 pm
I had no luck finding a cheaper alternative and just saved up for one. It was not terribly difficult to change just a little tight in areas.
fubar4774
Engine Size: 2.4
Postby DarthWookie » Fri Oct 01, 2010 8:54 pm
Finally got my school money, managed to squeeze enough extra out of it to buy one, thanks for the suggestions all. Oh, and I would post pics but the wifey brokeded her camera......*rolls eyes* its the third one in four years lol
DarthWookie
Return to Wanted
