Hey all, my 91 is in the garage apparently because the 3rd injector is only getting about 1/2 the voltage it should:(
the code on the board i need is MD163056 so if you've got one name your price lol
futat2 wrote:go to avproecm.com and check out there web site, thay rebuild the computers for our trucks and only charge $150 pluse $10 shipping. it comes with a lifetime garantee and thay have a fast turnaround. Thay are located out of floridia and do good work. I sent mine to them and got it back 3 days later but im located in VA. even if you decide not to use them thay have greate info on there web sight.
DroppedMitsu wrote:There has to be a problem in a wire in the harness somewhere, makes sense that if you switch plugs for the injector from another one it works fine.
camoit wrote:If the wires are like rock hard they are most likely high in resistance. So when the engine heats up the resistance goes up and voltage goes down in the wires. Have him put an ohm meter on the wires from one end to the other and look for resistance between the two and the others in the harness. If the resistance is high replace the wires. My Frieightliner has that problem with the Jacobs engine brake solonide. Every couple of years I need to change them out. The wires get hard and they drop cylinders because the voltage is low.
