mightyram50.net • View topic - 15 day pole. Pick a rim.
Forum rules
15 Day pole. What rim do you like? I want your feed back please. I will order them soon.
Poll ended at Thu Jul 01, 2010 10:10 pm
Click this one to vote for the rim on the RIGHT.
6
35%
Click this one to vote for the rim on the LEFT.
11
65%
Total votes : 17
Postby camoit » Thu Jun 17, 2010 2:18 pm
This is a 15 day pole to help me decide what rim to order. Thank You for your imput. Please only vote once.
I had the tire guy come by and show me some rims and tires.
I lean towards the rim on the right. But I also like the rim on the left. What do you think.
Rim size is 16 inch. 7 inch wide on the front. 10 inch wide on the rear.
Main diferance is the BIG holes on the left rim. It is a polished rim. The left rim is more indrustral looking.
The one on the left is an American Baja Polished The one on the right is an American Out Law 2 Spun finished.
Tires I might use. 7 inch front 10 inch rear
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Re: 15 day pole. Pick a rim.
Postby laidoutmits » Sun Jul 11, 2010 7:53 am
I know I'm late but I like the left one.
laidoutmits
Postby camoit » Fri Aug 20, 2010 5:24 pm
found a major hold up on the rims. I picked up 1 rim and tire. A front one, cost $400 Now the hold up s studs. I have spent 2 days trying to find some that fit with out to mutch mods. I found some chevy ones that pop right in the front, but the rears need some grinding .
camoit
Admin
Admin
Engine Size: 2.6L
Postby camoit » Sat Aug 28, 2010 11:22 pm
I found studs. rims are on order. It's the one that took the vote. 6 to 11.
camoit
Admin
Admin
Engine Size: 2.6L
Postby laidoutmits » Fri Oct 15, 2010 2:52 pm
No good without pics!!!
laidoutmits
Postby camoit » Fri Oct 15, 2010 3:40 pm
The votes said get the left side. So I now have a full set.
camoit
Admin
Admin
Engine Size: 2.6L
Postby daytonatrbo » Sun Oct 17, 2010 5:49 pm
what was the problem with the studs? did you need longer ones to fit the alloy rims?
daytonatrbo
Postby camoit » Sun Oct 17, 2010 10:55 pm
Yes the studs were to short. I need to sit down and wright up an up date on my build thread covering the pit falls of the studs and every thing else so far.
camoit
Admin
Admin
Engine Size: 2.6L
Postby daytonatrbo » Mon Oct 18, 2010 6:11 am
yeah, I noticed that the studs were really short when I was swapping rims around last night. My 20" didnt allow much more than a few mm of threads to show through, only got about 10 turns out of the lugs.
my isuzu rims are much better about that, the studs show a good 1/2 inch, and Ive been told that anything more than 3/8 is "enough" for a light truck. I think I would run the math before I drove it around with that little tho.
also, my isuzu trucks have the same thread size on the studs, and they use the same wheel-flange-separate-from-brake-hat in the front. They might be worth looking into for stud replacements, I might be able to take a closer look if you want.
daytonatrbo
Postby camoit » Mon Oct 18, 2010 10:01 am
Sorry if I might have gave you the wrong impression. But I have solved my problem. The front end is now a 2000 Nissan Extera / Frontier 2X4. and the rear is 97 Isuzu Rodeo. I spent several hours at Pep Boys with a Micrometer mesureing sholder widths. I didn't want to drill out the hubs. But I did need to grind down the sholders on the rear studs in order to clear the disk brake roter. I will explain the hole operation in my build thread under first gen. http://www.mightyram50.com/phpBB3/viewtopic.php?f=35&t=970 There will be some good tricks that I show on how to check fit and instalation of the studs.
camoit
Admin
Admin
Engine Size: 2.6L
Return to Wheel & Tire
