mightyram50.net • View topic - hub boring
hub boring
Forum rules
hub boring
Postby payrion » Fri May 21, 2010 9:08 pm
found out today that my rims need bored to match the mighty max, i called 5 machine shops and every one wanted 400 a set to bore out.. then a few people told me to bore it myself, they say since the rim is "lug centric" it doesnt need to be nuts on. but it will still come out pretty nuts on, i looked into this alot tonight and found so many people who do this on their trucks. WHAT DO YOU ALL THINK?
payrion
Re: hub boring
Postby LethalEthan » Fri May 21, 2010 9:14 pm
grind the tabs down on the front hubs and the rings on the drums with an angle grinder. Use acorn bulge lug nuts. It's easier, cheaper, and safer than having the wheels bored out
LethalEthan
Engine Size: 2.3L
Re: hub boring
Postby payrion » Fri May 21, 2010 9:19 pm
do i just grind the tabs, it looked to me like there is a raised ring even after the tabs would be ground down, i only got a few minutes to look tonight before the rain came.
payrion
Re: hub boring
Postby pennyman1 » Sat May 22, 2010 6:26 pm
Another alternative is to use 1/4" spacers between wheels and hub/drum. Not the best way, can cause clearance issues with wheelwells, and may require longer wheel studs.
Re: hub boring
Postby payrion » Sun May 23, 2010 6:06 am
i actually will be routing the the wheels, i ordered the correct lugs and watched a shop out here do a few sets for nissans this weekend, no sweat, it also balanced right up on their balance machine. i just need to borrow a router from a buddy tomorrow.
payrion
Re: hub boring
Postby LethalEthan » Sun May 23, 2010 9:26 am
dont take off to much or your wheels will crack
LethalEthan
Engine Size: 2.3L
Re: hub boring
Postby Mojave Magic » Sun May 23, 2010 11:11 am
I used a 4-3/16" hole saw but had access to a milling machine at the time. That was scary enough, I can't even imagine using a router unless you are amazing with it.
1988 Power Ram 50 75k miles SOLD :(
1998 Ram 3500 quad cab SLT Laramie 5.9 12v Cummins
Mojave Magic
Re: hub boring
Postby payrion » Sun May 23, 2010 12:26 pm
the shop i watched to them this weekend took 1/8 inch off at a time, it went like butter, my buddy john did his a few years ago and no cracks, i completely feel cool with this, i was up in the air when i started looking into it but now knowing that Damage has done a large amount since the 80's and never a problem, you just go slow and take off the minimum needed, ill be using a 3/8 bit and going 1/2 inch deep, same as a machine shop would do. and like i said the guys balanced them up with no problems at all.
payrion
Re: hub boring
Postby LethalEthan » Sun May 23, 2010 1:29 pm
as long as you feel comfortable doing it go for it. Ive seen shops do wheels though they'll be fine for a long time but they can crack eventually then your kinda fucked. Matt doesnt come here very often but he had a friend whose wheels cracked from being bored out. I believe he died in the wreck that happened afterwards.
LethalEthan
Engine Size: 2.3L
Return to Wheel & Tire
