mightyram50.net • View topic - This ebay item...
This ebay item...
This ebay item...
Postby 89powerram » Sat Jan 22, 2011 7:45 am
Could someone actually save 5% fuel and gain up to 7% more HP with this or a scam:
http://cgi.ebay.ca/Mitsubishi-Performan ... 255cc6ebb1
89powerram
Engine Size: 2.6L
Re: This ebay item...
Postby DroppedMitsu » Sat Jan 22, 2011 10:16 am
Its a scam
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Postby reddevillhs17 » Sat Jan 22, 2011 11:44 am
i could see it sorting out some electrical issues but hp, torque and fuel gain im not so sure about
reddevillhs17
Engine Size: 2.4
Postby reddevillhs17 » Sat Jan 22, 2011 11:49 am
and it looks to me like you could just clean up the grounds you already have and maybe add some more like the kit, and that could sort out some electrical issues.
think i'd try that before i got that kit
reddevillhs17
Engine Size: 2.4
Postby pennyman1 » Sat Jan 22, 2011 1:36 pm
Stereo stiffening cap will do that and make the stereo hit hard. Grounding everything back to the battery is the best fix on any vehicle.
Postby 4doorciv » Fri Jan 28, 2011 12:40 am
I agree with pennyman1 and reddevillhs17 on this. I would not trust that ebay item. You could also upgrade your alternator if You need the extra amperage for a sound setup or extra electrical loads.
-Ryan-
4doorciv
Engine Size: 4g63
Return to General Questions.
