6G73 swap into 2nd gen MM
Postby sacredauto » Tue Oct 19, 2010 3:11 pm
i've got a 2.6, 5 speed MM, and i have an N/A 3000GT whose transmission failed on me so i've got a 6G73 sitting around wanting to go in something and was wondering if anyone knew if the transmission in my truck would bolt up. or maybe if it were like nissans where the transmission is the same but the bellhousing is different between the 4 cylinders and V6's
sacredauto
Location: Northeast NC, Southeast VA, right on the border
Engine Size: 2.6L
Re: 6G73 swap into 2nd gen MM
Postby pennyman1 » Tue Oct 19, 2010 7:04 pm
It should work, but you want to use the flywheel and clutch disc from a 88-89 intercooled starquest - its a 240 mm disc that matches the splines on the input shaft
Postby sacredauto » Wed Oct 20, 2010 2:38 am
thanks. that'll be the hard part. DSM parts aren't very common around here
sacredauto
Engine Size: 2.6L
Postby Josh2g » Mon Oct 25, 2010 6:37 am
Is it a 6g73 or a 6g72? Either way this would be a pretty cool swap. I have a Km-132 trans if you ever want to see if they match up, Im in South NC.
Josh2g
Engine Size: 2.4L
Postby sacredauto » Sat Oct 30, 2010 10:54 pm
it's a 6G73, i'm actually thinking about trying to pick up a shortbed max from a guy down the road from me that's the same as mine except for the paint and bed and throw it in that
sacredauto
Engine Size: 2.6L
Return to General Questions.
