mightyram50.net • View topic - Zerk Locations 1990 Max 50 2.4 Automatic
Postby Alohauser » Tue Sep 14, 2010 7:41 pm
Anyone tell me where the grease points are on the 1990 Max 50?
James
Alohauser
Engine Size: 2.4
Return to General Questions.
