mightyram50.net • View topic - 1993 Might Max, need swap answers
Postby Might93 » Sun May 17, 2009 7:03 pm
Hey everyone, so me and my buddy just picked up a 1993 Might Max truck. The guy was trying to swap a 4g63 head onto it. He got the old head off and the new head on with one bolt then the rest is a grey area as to what happened. But anyways, we are going to do a motor swap and need a lot of questions answered. I tried searching google for about 2 hours and went to mightd50.com and could not register which led me here. Hoping I can get some help. What is the most common and easy swap on these? He wants to do a 350 and I want to do a 302. Anyone got any opinions on these two swaps? And is it possible to get a 4g63 into one of these? Whats the tranny like in these trucks? If it bolts to a 4g will it hold up? And for rear end, has anyone done a 8.8 or a 9"? Thank you very much in advance.
1994 Mighty Max, 4G64 block, 4G63 head. HKS cams, Wiseco Pistons, Eagle H Beam rods, .63 t3 turbo, ACT HD Clutch. Dropped 2"
Might93
Donator
Donator
Re: 1993 Might Max, need swap answers
Postby RusTy Max » Sun May 17, 2009 7:09 pm
There are tons of info floating around about all of these swaps. You can do a 350 swap, a 302 swap or a 4g63t swap. We are working on doing a FULL WRITEUP including pictures for each and all of these swaps including wiring diagrams and tips/tricks. But it's an ongoing process. Check out the link just below your post named http://www.mightyram50.com/phpBB3/full-4g63t-swap-info%C7%83-t44.html
Also the 302 is a VERY POPULAR swap. Almost bolt-on. As is the 350 with modifications. I hope this helps... and keep checking back, we'll get working on the other information.
RusTy Max
Engine Size: 2.4L
Postby Might93 » Sun May 17, 2009 7:24 pm
Thanks this really helps. I am going to see if my friend has a donor mustang in his junkyard for a donor car. He want to do a 350 just because his dad has one out of a old farm truck. I would like to do a 4G63 because we both had GSXs but he really didnt like his for some reason.
Might93
Donator
Donator
Postby RusTy Max » Sun May 17, 2009 7:25 pm
If you have an old 4g63t laying around send it my way! ;)
RusTy Max
Engine Size: 2.4L
Postby Might93 » Sun May 17, 2009 7:39 pm
No we sold them a while ago, try tigerjapanese.com or jdmtigerjapanese.com they have JDM motors for a good price. What tranny should we use for a 4G swap? Seeing as the stock eclipse trans will be a transaxle
Might93
Donator
Donator
Postby RusTy Max » Sun May 17, 2009 7:46 pm
Use the trans off a 2.0L mighty max or D50. The info is in the swap post below this post.
RusTy Max
Engine Size: 2.4L
Postby Might93 » Sun May 17, 2009 8:09 pm
I read that post but I dont really want to trust a 2.0 tranny out of a hundred horse pickup :-/
Might93
Donator
Donator
Postby RusTy Max » Sun May 17, 2009 8:10 pm
It's been tested multiple times. It will hold up! Depends on your boost goals, but for the most part will hold no problems.
RusTy Max
Engine Size: 2.4L
Postby Might93 » Sun May 17, 2009 8:18 pm
Well I am hoping for about 400 horse, which is what my Rumble Bee has, but weighs like 2000 pounds less
Might93
Donator
Donator
Postby Might93 » Sun May 17, 2009 8:19 pm
Where can I find the part off a conquest/starion?
Might93
Donator
Donator
Return to General Questions.
