mightyram50.net • View topic - High beams won't turn on
Postby andrew » Tue Dec 28, 2010 4:06 am
I have 1988 d50 and my high beams won't turn on when I pull the switch. I have replaced the bulbs and still don't work.
andrew
Re: High beams won't turn on
Postby 4doorciv » Tue Dec 28, 2010 8:25 am
Sounds to me like an electric issue. Did you check your fuses and fusable links? You got a test light or multimeter?
-Ryan-
4doorciv
Engine Size: 4g63
Postby andrew » Tue Dec 28, 2010 4:53 pm
I checked the fuses and they are ok. But how do you check the fusable links I have a multimeter. Can it be a relay?
andrew
Postby 4doorciv » Tue Dec 28, 2010 5:41 pm
Fusable links are in a small black box near the brake booster. They are really easy to tell if they are broken. They get replaced but you make your own. Gotta buy a roll of the stuff and crimp spade connectors so they'll work. That is if they are broken.
-Ryan-
4doorciv
Engine Size: 4g63
Postby andrew » Tue Dec 28, 2010 10:26 pm
Nope not the fuseable links they look fine I'll check the relay tomorrow cuz it's raining.
andrew
Postby 4doorciv » Tue Dec 28, 2010 10:47 pm
Is there 12v at the headlight with low beam as well as high beam? Are you sure it isn't the fuses? If it's not a fuse then it could be the switch or wiring harness. Glad you got a multimeter. Please update when you continue to diagnose.
-Ryan-
4doorciv
Engine Size: 4g63
Postby pennyman1 » Wed Dec 29, 2010 3:37 pm
Check the tension on the fuse socket for the high beam fuse and chek the back of the block for corrosion. After 22+ years the sides of the fuse holder gets weak and won't make good connection. windshield leaks are common right above the fuse block also.
Postby mikewarme » Wed Dec 29, 2010 6:52 pm
Did you check to make sure the bulbs arent both out? I had that happen before. Otherwise for sure relay. Can't remmember where it is on the 2nd gen
mikewarme
Engine Size: 2.3
Postby 4doorciv » Wed Dec 29, 2010 7:45 pm
is that where the water is coming from in my truck? I was ready to pull the carpet and make a few drain holes through frustration. Lol.
-Ryan-
4doorciv
Engine Size: 4g63
Return to Lighting
