 by T-Bone » Wed Mar 02, 2011 5:17 pm
			Okay so somehow I jacked up the timeing while redoing my seals.  Is there are way to time the engine without using the marks.  I lined up the marks on the pump, cam shaft, and the crank sprocket before I took the belts off.  Now when I put the crank pully on it does not line up with the TDC mark on the plastic cover.   Any help is very much appreciated.
