by DroppedMitsu » Mon Mar 29, 2010 10:23 am
You preferably want the 6 bolt engines, 91-92(90 will work also, just has diffent electrical plugs on certain sensors).93-up will work also but they are the less desirable 7 bolt engines. Any of those years will work with stock truck mounts, but the cas and thermostat will be touching the firewall, so you might want to fab up some brackets to move it up an inch or two. The 5 speed manual(KM132) from a g63b(2.0L carbed engine) mighty max/Ram 50 will bolt right up to the engine.
-Josh-
1989 Macrocab Mighty Max
