Help on head???
Help on head???
Postby Tsi1g » Thu Mar 11, 2010 6:47 am
I was wondering if I could put a 1 or 2g turbo head on my truck it is a 92 2.4 mighty max I want to put a turbo head on it and run 5 psi I was just wondering if it could be done
Tsi1g
Engine Size: 2.4
Re: Help on head???
Postby mxmikie » Thu Mar 11, 2010 7:17 am
yes
mxmikie
Engine Size: 2.4
Re: Help on head???
Postby Tsi1g » Thu Mar 11, 2010 7:36 am
How would I wire in the cas? Do I have to put a turbo engin harness in? And can I use a 1g head or do I have to find a 2g?
Tsi1g
Engine Size: 2.4
Re: Help on head???
Postby DroppedMitsu » Thu Mar 11, 2010 1:56 pm
Yuo can use either gen head, you will want pistons from wiseco to lower the comp, you will need parts form another dohc motor so the timing setup will be right. Check out projectzerog.com and ask around there or search through the threads as there are a few ppl that have done the swap.
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Return to Turbo & Blowers
