mightyram50.net • View topic - Valve Stem Seals
Valve Stem Seals
Valve Stem Seals
Postby tekjones83 » Thu Mar 24, 2011 12:00 pm
As the title said How to replace those without goin to the machine shop? :)
tekjones83
Engine Size: 20
Re: Valve Stem Seals
Postby D50DAVE » Thu Mar 24, 2011 4:39 pm
Pretty easy but time consuming. Strip the valvetrain from the head, remove spark plugs,use compressed air to hold the valves closed, remove springs and seals and replace. In place of a compressor you can feed some small nylon rope into the cylinder and rotate the crank to bring the piston up against the rope and the bottom of the valves.
D50DAVE
Postby tekjones83 » Thu Mar 24, 2011 7:18 pm
yea i have a air compressor to do that with thats a great idea and how do take out the valve stem seals and put them in?
tekjones83
Engine Size: 20
Postby D50DAVE » Fri Mar 25, 2011 5:11 am
Get the new ones before you start, you'll see how they work.
D50DAVE
Postby tekjones83 » Fri Mar 25, 2011 6:02 am
Aight will do lol
tekjones83
Engine Size: 20
Postby camoit » Fri Mar 25, 2011 8:07 pm
Keep in mind you will use a lot of air.
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Return to Head & Block
